So Many Roads
Currently replacing stock front shocks with Bilstein HD's (24-187244) in the front of a '99 SR5 with 99 tall springs (front drivers side is blue/pink). Looks like the HD's are about 1 1/2" longer than the stock shocks, so there will be less preload on the spring. After I put the two retainers, two cushions and the top plate on the HD, there is only one thread showing on the shock post.
Is it right that the spring will have less preload on it with the HD shock? Just back out the spring compressors after the top nut has been attached to take up that 1.5"?
Any concern about the number of threads to crank down the top nut that holds the top plate in place? I'm assuming the rubber cushions will compress and there will be plenty of threads in contact with the the top nut.
Thanks - Eric
Thanks - Eric
