Front brake problem
Bigmd
Ok, driving on highway the other day car starts shuttering when i was slowing down. The last time it happened my pass caliper was stuck. I had it replaced and no problems for almost two years. I figure it’s the other side now. They are the Tundra 199mm calipers. I jack up driver side and it seems ok with a little drag when i spin wheel. Did same with pass side and it’s tough to spin. I check caliper pins and they are very rusty. I cleaned them up to a nice smooth shine and reinstalled with a little grease. Drove on highway and it seems better but not completely fixed. I checked driver side again and it’s got way to much drag. I clean those pins too and reinstall. Something isn’t right as both wheels still will not spin freely. Besides the calipers being frozen what else can cause this. Fluid is just below max level. Don’t want to start buying parts until i know.
Well i did one side at a time mainly because i don’t know where to jack in center of truck. I jacked from control arm so hardly any droop. I think what I’m gonna do is take calipers off and drop them off at my powdercoater with a rebuilt kit. He can blast them coat them and reassemble.
Stranger things have happened, friend. It's worth checking. But I also had a similar problem for a while, turns out my driver's side CV axle was bound up and needed replacing. Put a new one in and the problem went away.
seltzernator
