Front Diff and ADD torque specs?
TBuzz
I've searched to no avail, so here I am. Finally working on the rig again. It's been apart so long I'm not sure of a couple things.
1)Anyone know the TS for the E14 bolts that hold the ADD on?
2)Torque specs for the diff mounts to the diff and ADD?
3)Is there a gasket between the diff and the unit that the actuator goes into or is it just the FIPg there?
4)I cleaned blue loctite off the E14 long bolts, guess I out that back on?
Anyone her or are you all gone having fun.
Thanks in advance
front diff install
While I'm at it here's another. I'm putting front diff in today and it was a bear last time. For those that have done it which method did u use?
A) Just did it
B) Took off the rear mounting cushion to get the diff in. If this how bad was it getting the bolts in after that?
I only want to do this one more time
I believe the Torque Specs you want are in here. I haven't done this job so I can't comment on difficulty.
A) Just did it
I put mine on a floor jack to raise it up. Had a friend in my case to help wrestle it into place. It's a pain getting the diff past the bell housing.
