I have an 07 4Runner part time 4wd. V6.
Just replaced all suspension with toytec, did UCA, and while I was at it did both cv shafts even though only one of them was puking bad enough to need fixing. So with the shafts I did new seals.
I noticed last night doing a test drive that it's perfectly fine in 4wd. But as soon I go to 2wd, I can barely hear and feel that womp womp grinding/bearing noise up front. I'm guessing it's the bearing you all are discussing.
Do I try and take this TSB to Toyota and see what they say? Or buy the ecgs bushing kit and see if that solves the problem. This is my DD so it's starting to get frustrating. And my wallet is shrinking fast. I fix one thing and two more things present themselves.
Did you end up trying to get Toyota to replace the bearing for you?
