Front end clunk what could it be? V8 4WD
I'M ALL IN! I'm going to buy the energy suspension master rebuild kit and replace the bushings to see if the problem persists.
After giving it a lot of thought I think I am going with the front passenger CV axle before I do anything else. I found one at my local auto parts store not rebuilt but new with a lifetime warranty for $50 does it sound too good to be true?
Did you ever figure out what was clunking? I have a clunk in the front end too that is driving me nuts. Took a video of it. Same sound by chance? Mine does it all the time.. Turning, braking, driving straight, over speed bumps... Changed the front coilovers, sway bar bushings, everything else is tight and looks good..
Click here to hear what I'm hearing...
Nope haven't got around to it yet. I bought a used transfer case for $200 all 3 o rings for the actuator and a tube of rtv. The o rings from colonal seal just got in a few days ago so I just have to do the work and I'm feeling lazy in this heat. I'm only doing the transfer case because someone had the same exact symptoms as me sounds like a machine gun under acceleration and my transfer case was bone dry. I already lubed both drive shafts and pulled the rear diff and inspected it. It looked fine so did the gears and oil. I put it back and now I'm on the T case.
