Front End Grinding
mik824
Not sure what is going on with the front end of my vehicle but I have perpetuating grinding noise that occurs when I accelerate or decelerate the car about 10 mph. SUV has 136k miles.
At first I brought it to a Yota mechanic who replaced the passenger side wheel bearing. I also had both front calipers replaced because of seizing which resulted in two rotors + pads and fluids.
The noise problem reduced for a bit then came back. The next time, I went into a Yota dealership, had their inspection performed and the outcome was the Tech did not see any mechanical problems. He confirmed that both wheel bearings were in good shape. Noticed that steering boots were loose, but nothing to fix asap or related to this problem. I ended up replacing all the front, center (trans case) and rear differentials oils replaced by Toyota. I was told that the fluid in the front differential came out with light sparkles-- this was original fluid in the suv.
The noise grind has exacerbated since the Toyota did their service. I noticed today that on the highway that when my vehicle moves on a banked road, the grinding noise goes away. I do not see any signs of rubbing. I do have cornfed lift on the stock suspensions, and 4 wheel hub spacers. Tires have been checked for alignment, which came out good. Tires are rotated, 55k Cooper discovery, currently with 31k miles on them.
Thoughts on what this problem can be?
dont know about the sparkles.....
if its metal shavings it could be bad...and would recommend changing fluids the check drain plug for metal
but keep it simple first
check your rotor dust sheilds.....
if your in ny they might have bent up a lil with all the snow or ice
also try turning wheel from lock to lock and see if any squeaking "bj's"
could be u joints on drive shaft
but being you said it goes away on banking roads...i will say wheel bearing......
if the seals were not done properly a new bearing does no good
a guy in nj will ship one reading to bolt on in a few days for a few $
also check your break pads
Not sure you will check this thread again but, if you do...
What you may be hearing is your gears in your front diff. Since the diff is connected to the frame, the grinding noise can be exaggerated. Not sure if you have a V8 AWD or a V6 part time and if it a V6 if it does it in 2wd also.
But if it is worn pinion gears causing the Howling (sounds like grinding when it reverberates through the frame) it's not a huge issue. Fact is, unless you are hard on the 4Runner you can put 100k miles on worn gears. You mace have gotten some moisture in the front diff, causing some pitting and some wear...and never having changed the fluid cannot help much either.
If this is the case, you have a couple options; leave it alone and keep the fluids on a regular service schedule from here on out. Or, replace the gears set.
IMO, I say run it.
Also the above mentioned dust shield can also be a source of noise, but is not exaggerated during braking and acceleration like the gears would.
I have been a member on this forum since 2005. My membership just had a relapse a little since I haven't had much issues with the vehicle. The vehicle is a v6. Good food for thought. Gonna run these ideas past a mechanic.
Thank you for your responses. I will check obvious rust spots tomorrow morning. Regards.
Close-out
Just wanted to complete the post-- the fault for the front wheel grind was due to a worn out wheel bearing, driver side.
I appreciate all of the insights- Regards.
utkrstam
