front end squeak.... help!
MadeInMaine
The front end squeak started after I upgraded to ToyTec COs, I did not change UCAs.
It happens on slow little bumps/speed bumps. Probably when I am driving faster, but I can't hear it.
I have attached 2 videos, one from driver and passenger side, of my applying a bit of weight to my C4 bumper.
Please help with any knowledge of the where the squeak is coming from and how to fix it.
Thank you so much
Owen
YouTube
YouTube
<iframe width="904" height="509" src="https://www.youtube.com/embed/DXLWKNsZQkQ" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
<iframe width="904" height="509" src="https://www.youtube.com/embed/Va10avDuw80" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Can't see the videos they are currently private. Do you have any poly bushings they do tend to squeak.
It is public now, you can watch the videos. Thanks for letting me know.
Poly bushings? I didn't replace any when I upgraded the COs, so I would assume not.
But to be honest, I don't know. Sad, sorry.
That's fairly louder then a squeak. Préassembled coil overs? Sounds to me like the lower control arms or sway bar bushings are binding. Get under there and have someone else jump on the front bumper. you could also recheck the bolt torques and if everything is goodntight then you can also use wd40 water resistant silicone spray safe for rubber. Good luck.
That's fairly louder then a squeak. Préassembled coil overs? Sounds to me like the lower control arms or sway bar bushings are binding. Get under there and have someone else jump on the front bumper. you could also recheck the bolt torques and if everything is good night then you can also use wd40 water resistant silicone spray safe for rubber. Good luck.
Preassembled COs, yes
holy moly that sounds like a goose is stuck in there
I second the above, you're going to have to get under there while someone rocks the truck. something is rubbing on something else. It should be pretty obvious when you can get under there and touch stuff
