Front Hitch Receiver
That looks like a good fit and fits fairly snug. Guess I will pull the trigger and buy them for my 16 TE to mainly use for a bike rack.
Just understand you will not get the longer frame bolts and washers in the Curt kit but that may not be a problem for a TE.
Looks good! A much more compact fit. You can barely tell it's there. As an added benefit it's pulling force puts much less twisting force on the frame rail ends, so it should be stronger too.
And way mo bedda da kine on approach angle and ground clearance
Just put the 31054 up for sale on the 5TH Gen For Sale thread to see if there is any interest. However, I ain't holdin' me breath.
Thought you might like to see the final product
First pic is the overall mounting of the two (front / rear) cooler / fishin' rod racks to my 2016 4Runner SR5 4WD
Second pic is the front rack mount using the Curt 31367 front hitch receiver with a Curt 45791 8 inch extender with a Hitch Haul Z / Lift bar that the rack is mounted to. The extender is needed to get the receiver further out so the Z bar clears the bumper.
Third pic is the rear rack mount using the stock rear receiver with a Curt 45792 8 inch dual extender with the rack Z / Lift bar in the top extender receiver.
The turnbuckles / chains seen on both are to prevent the racks from wobbling side to side and bouncing up / down.
This setup vastly improves the approach and departure angles of the two racks over the original setup with the Curt 31054 front receiver and no dual extender on the rear
Great addition with the turnbuckles. I was wondering about wobble/bounce. That would solve that problem nicely.
Cheers,
Z
Do you guys think that the 31367 is strong enough for front recovery?
It looks like it bolts "straight" onto the frame. I am looking at doing this, for a front mounted Smittybilt receiver shackle for recovery.
Just wanted to get the opinions of you guys that have this front hitch, or others with wisdom on the subject.
Also, Salvo Jimmy, do you know what size the bolts that you needed for the 31367 were? You mentioned them briefly when you made the swap.
I just ordered a 31367 after reading this. I would also like to know about the needed bolts so I can pick some up.
Thanks,
Chris
This link http://www.toyota-4runner.org/5th-gen-t4rs/166382-custom-front-shackel-mounts-2.htmlight help. Post #26. "Strong enough" is relative depending on recovery method. I remember this because I spent a lot of time on this answer.
[MENTION=148184]WaldoOneFive[/MENTION] [MENTION=110745]Belcher[/MENTION]
I don't have the bolt size because I used the ones that came from Curt with the 2 hitches I had. Of course the diameter / thread is that of the frame bolts and the longer bolts were about a 1/4" longer than the frame bolts.
Caution: There are bolts and there are bolts. Whatever you may have to substitute should be the same strength as the frame bolts, or the Curt supplied bolts if they happen to be stronger.
And 1engineer link is a must read.
Thank you guys so much for that info. The technical info, and the new updated info on the Curt front hitch options.
After looking at them both, I am still favoring the 31367 as it still fits tighter up to the front bumper on the 5th Gens.
I will definitely look into not only the longer bolts, but the quality and rating of them.
Hey guys,
Got my 31367 yesterday. Started getting into the install a little. It indeed will work with some minor bolt problems as described.
What I found. You will need (for my 2014 trail):
(4) 1 1/2" long Metric 10x1.25 bolts....grade 10.9 (which is the metric equiv. of grade 8 as I understand it.)
(4) Grade 8 - 7/16" fender washers for the Metric bolts...they don't make 10.9 washers or Grade 8 metric stuff.
(2) 5/8" 11 pitch Grade 8 carriage bolts- 2 1/2" long. For some reason the ones shipped from Curt I could not get them to start threading since they were so short. (maybe the trail factory tow hooks are a little meatier on the newer models) Reuse the Curt provided flange nuts.
Some of this stuff is hard to get your hands on so don't be like me and prepare ahead of time...everything around here is closed on the weekend and can't be found at Home Depot.
Hope this helps,
Chris
Hey guys,
Hope this helps,
Chris
Awesome info, thank you!!
I discovered an alternative front hitch to the Curt models. I recently installed a Draw-Tite front tow hitch. It'll be used to run racks, a recovery point, a temporary winch, or possibly move trailers around. It has a verticle load rating of 500 lbs, and a 9000 lb straight-pull rating.
Draw-Tite came out with this hitch last year (p/n 65074). It is tucked up against the bottom of the plastic factory radiator cover plate pretty tight, and doesn't use up the factory tie-down points to secure it to the frame the way the Curt hitches do (it uses two of the bumper bracket bolts plus a large side bolt on each frame rail). So using the factory tie-down points to help with angled recovery is still an option. It is a simpler design than the Curt, with thick, straight mounting plates and slightly longer transverse tubes. At 29 lbs, I think it may also be slightly lighter.
adventureman-albums-%26quot%3Bthe+rhino%26quot%3B-picture49064-draw-tite-front-tow-hitch.jpg
It doesn't compromise the ground clearance, although it probably does reduce the approach angle (this truck's is not a rock crawler anyway).
adventureman-albums-%26quot%3Bthe+rhino%26quot%3B-picture49065-draw-tite-front-tow-hitch.jpg
I installed that same hitch last summer and it is great. Easy install!
I've ordered the Curt 31054 Front Mount Hitch receiver, for my 2019 4Runner Nightshade, coupled with a DNA Motoring Cradle Winch Mount. Decided on the Vevor 10,000# Electric Winch with Wireless and Wired Remote. They'll be in the first of next week and I'll get them installed and by then hopefully this 100+ degree weather will break and I can get back to clearing the farm. I mainly use my 4Runner for working on the farm, not a lot of off road activity, but with the cradle mount I can use it on the front or the back.
tuṣṭāva
