Front lift measurements (no flares)
cj80cruiser
Senior Member
I have found several threads with the measurements I'm looking for but everyone I've seen are from sr5, limited,or sport models. Does anyone have center of wheel to fender measurements on a flareless 4runner?
I don't think I got more than an inch of lift from my ironman front springs and 5100 tundras set on the bottom perch.
Unfortunately, that could be about right. The few pics I've seen of the complete Iron Man the front was pretty low,and the back a little tall. I think the person didn't get the 2in front they were expecting. Sorry I can't find the thread I'm thinking of... currently posting from my phone.
I remember that the rears were super high but they were rated for something like 660lbs so I went a different direction with the rear since I wouldn't have that much weight to bring the springs down.
If someone has a 3" lift and no flares the wheel center to fender edge measurement would be appreciated for the front just to give me an idea where I need to be. I have adjustable Tundras so I can hopefully get these ironmans to work or I'll be ordering eibachs from toytec if I cant.
yep, that should be about it because the stock 1999 Highlander was about 21 inches from hub center to bottom of flare. The 1999 Highlander was 1-inch taller than the 1998 which sat at 20 inches.
Please note that the amount of lift is relative to the stock height. If you have a stock 1999 Highlander, then you only get a 2-inch lift. If you have the 2002 low-rider, you'll get a 4" lift.
DJNutshell
