Front Passenger Door - No power
ZoneOne
Gents,
I want to pick your brain for things to look for once I pull off the panel.
My front passenger door has NO POWER. The door won't lock/unlock with the rest, nor will the window go down (luckily it's up) and the powered rear view mirror will not move.
The door locks manually fine and opens and shuts as normal.
I plan to take the panel off and take a look but until I get a few replies here, I honestly have no idea what I'm looking for.
Any help would be appreciated it. :faint:
I have checked all fuses and all are good. Additionally, all my switches work for all other windows and all other doors work when pressing the unlock button on the driver side door.
Probably the wire(s) inside the rubber boot between the door hinges is broken. This is very common on the driver side but you have it on the passenger side. Remove the kick panel and disconnect the door wire plug from the main harness. Do a continuity check. If a wire is broken, you have to remove the rubber boot from the door and body and slide it forward/backward to solder the wire.
2001ATL
