Front Range Offroad TWINSTICK
The Front Range Offroad Twin-Stick allows the use of two-wheel drive low range, and a true neutral. As well as the ability to shift-on-the-fly, while in low range, from 2wd to 4wd and back easily, this is especially useful with a locker in the front axle, and allows for a tighter turning radius. With the factory shifter configuration, neutral only disengages the transfer case from the transmission. This actually has the front and rear drivelines locked together
Front Range Offroad's Twinstick comes in many bases, so you can install a twinstick into any Toyota Tcase!
Get yours today at Front Range-Twinstick
I have twin sticks installed on my '74 Bronco. Works well and useful. Plus, it looks bad ass. Not sure if this would work w a 5th gen?
erinobr2000
