Front Rotors 319 mm or 338 mm??s
h7009
Hey to all anyboby out there know how to tell if a rotor is 319 or 338mm??? I don't have a mm measure, any suggestions would be appreciated. thanks, CSM-H
Call the dealer's parts department, provide them the VIN and they will be able to tell.
319 mm (12.56") is what's on the SR5 and the Limited.
338 mm (13.30") is the special larger disc on the Sport Edition.
true to some extent. koz (limited) and bostonkevin (sr5) both have the larger rotors. the dealer should be able to run a vin filter to determine the trucks build and find the correct rotor size.
Rotor size....
thanks for the replys, I went to the dealer and gave them th eVIN, because mine has an "SR5 appearance package" it supposedly has the larger diameter discs......Who ever owned my 4runneordered it with a lot of the Sport package stuff. again thanks, CSM-H
Hate to bump this super old thread, but I ran into this issue. I have the 17" wheels and ordered everything off RockAuto based on that 17" wheel spec. I apparently have the calipers and 338mm rotors for the sport package and my 4runner came with the 319mm rotors. My brake pedal goes almost to the floor to stop, but does stop ok. What can I do to get pedal feel back, is it the master cylinder, proportioning valve or what? Should I just go back to all the smaller stuff?
Listing everything by wheel size really screwed me up!
Brent
charlesz
