Front skid plate bolt size?
Put the new bolts in this morning.......
......while doing an oil/filter change. I had slightly tapered the bolt ends, to help with threading on.
Other than being a little tight going on (a little used oil helped)......they tightened up just fine. They do require a 13mm socket, as opposed to the old bolts needing a 12mm.
Lastly......there's comfort in knowing that the original bolts will NOT be trying to cut/cross-thread.....every time I do an oil change.
Kevin
Ambrose67
