Mark86 said:I just replaced my wipers today. The front driver is 550mm and the front passenger is 500mm.
Based off of Mark's mm measurements, I calculated 22" and 20". 550mm/25.4mm = ~21.6 and 500mm/25.4mm = ~19.6.Sac State said:English man, English!
Thanks, is that 21" or 23"?
Mark86 said:Sorry about that. I picked mine up at the dealer so they are straight from Japan. They only give the measurements in mm on the packaging and I couldn't find it in inches.
Sac State said:Thanks Mark, is that the entire arm or just the rubber blade?
Out of curiosity, how much was the set?Mark86 said:It is the entire arm. You have to press in the tab on the bottom and slide it off. The fronts are very easy to change, the back windshield is a pain!
jharris2 said:Out of curiosity, how much was the set?
ToolmanJohn said:Buy the entire blade , not the refills. It's easier to replace that way, and not expensive. Don't spend more than $5, they aren't worth it.
I tried some Lifetime warranty silicone blades, blah blah... They streaked like crazy, could not keep them from streaking. So I replaced them with some cheap Wal-Mart blades. They work perfect. Go figure.
The rear wiper I can't remember what size it is.
