FS: 1998 Toyota 4Runner SR5 5 Speed 4X4 | Northern CA - $10,500 REDUCED
EcoResto8
Year / Make / Model: 1998 Toyota 4Runner SR5
Mileage: 230K (228,652 right now and might go up before I sell)
Drivetrain: 3.4L V6 | 5 Speed | 4WD (J Shift)| 4:10 Gears | NON E-Locker Option
Color: Evergreen Pearl (751)
Interior: Steel Metallic and Moon Mist interior | Sunroof
Tow Package
Clean Title
Clean Carfax
Wheels / Tires: 4Runner 5 star Wheels 265/75/r16 Goodyear Duratracs (90% Tread Left)
Asking Price: $ 10,500
Background:
I bought my 4Runner back in 2016 from the original owner. Before my ownership, the vehicle was used as a personal fleet rig in a Southern Californian construction business. It was primarily serviced at a Toyota dealership until I bought it, and started doing the maintenance myself with OEM parts when applicable. I used this vehicle for my DD / weekend camping warier over the years and it has been great. I had plans to add a super charger, and tow my AE86 track vehicle with it…Nonetheless, plans changed and I no longer use the 4Runner. I kept the vehicle primarily stock, except for a cold air intake and the slightly larger tires. I thought I would never sell this beauty…
Maintenance:
As I mentioned earlier, the 4Runner was mainly serviced throughout its life at a Toyota Dealership before my ownership. You can look up the vin via the Toyota website for more info. I have kept the maintenance records since I bought it and some records from Toyota Dealer. The list is as follows:
227,102 – (Me) Oil Change, Oil Filter.
223,018 – (Me) Oil Change, Oil Filter, New Goodyear Duratracs (265/75/r16).
220,355 – (Dealer/Me) Oil Change, Oil Filter. Took to dealer because I couldn’t find out why the car was throwing a (P1300) code. Dealer couldn’t replicate code (go figure) and suggest I change ignitor. I replaced ignitor with junk yard one and code hasn’t come back.
217,102 – (Me) Oil Change, Oil Filter.
213,509 – (Me) Oil Change, Oil Filter, OEM Lower Ball Joints.
210,200 – (Me) Oil Change, Oil Filter, Front and Rear Shock Replacement.
206,036 – (Me) Oil Change, Oil Filter, OEM Cylinder #6 Fuel Injector, OEM Fuel Filter, OEM Valve Cover Gaskets, Denso Spark Plugs, Plug Wires, Coil Boots, PCV Valve, K&N Cold Air Intake, Tacoma Whip Mod, Battery Replacement, High Flow Catalytic Convertor.
203,798 – (Me) Oil Change, Oil Filter.
199,600 – (Me) Oil Change, Front and Rear Differential Flush, Transmission Flush, Transfer Case Flush.
199,238 – (Dealer) Oil change, Timing Belt Set, Water Pump Assembly, Drive Belts, Coolant Flush.
187,738 – (Dealer) Replaced Fuses, Antitheft Alarm System Removed, Battery Replaced (Previous owner removed alarm because battery would always die when he left it in his warehouse).
174,360 – (Dealer) New Starter.
157,261 – (Dealer) Oil change, Timing Belt Set, Water Pump Assembly, Drive Belts, Coolant Flush.
139,647 – (Dealer) 15,000 mile service.
110,201 – (Dealer) 30,000 mile service, Tune-up Performed, Windshield Replaced.
How does it run, drive, startup, etc.?
For a 20+ year old vehicle, I would not hesitate to drive it across country. It starts right up every time, drives smooth, shifts well, doesn't burn oil, etc. You will see in the pictures that I replaced the original wheels with 3rd gen 5 star wheels. I wanted the 4Runner to keep a stock look to it.
Concerns:
Well, it is a 20 + year old car. It does have some things that I wanted to fix eventually…
- Clear coat on roof and back hatch has seen better days.
- Paint has scratch marks throughout from brush on unmanaged forest service roads (could buff out possibly).
- Clutch slave had slight leak years ago, but stopped leaking (New OEM clutch slave that will come with sale).
- Oil residue from previous valve cover leak on exhaust manifold heat shield.
- Clutch chirping when cold ( After at running temp it is fine). It is original clutch and needs to be replaced anyway.
- Non E-Locker (I have a OEM 4:10 E-Locker for sale).
- Inner tie rods will need to be replaced soonish. (New OEM rack and pinion, but high-pressure line threads are damaged…could fix the threads… will come with sale).
- “Low level” gas light flickers randomly. Gas gauge works perfectly, just the light illuminates at any fuel level. I didn’t want to drop the gas tank to fix sensor short.
Overall, this was a great vehicle with many memories. Pictures down below in link.
Imgur: The magic of the Internet
A few more photos... I live on a dirt road, so its a somewhat dusty. Offers are always welcome.
Hello, My name is Thomas. I am interested in this 4 Runner. Is it still available? If it is maybe I can come take a look at it. I am currently living in SoCal (Ventura) so I am not too far away. Please let me know.
