FS: 2000 4Runner - $16,500 OBO - San Diego, CA
MillerPKA
2000 Toyota 4runner SR5
3.4L Supercharged V6
Auto w/ e-locker
Mininal rust, overall great condition
Registered in CA until Jan 2020 - smog due in 2021.
$13,500 OBO
This is a project that's mostly complete, but has some maintenance needed to get this to 100%. I'm including my personal progress and to-do list below that has every single issue or task that I know of.
I purchased the truck stock in 2016, and learned after the gauge cluster had been swapped to reflect lower mileage. Odometer reads 17x,xxx but guessing the true mileage is around 290k.
Here are all of the known issues:
- Head gasket is failing. Still runs and drives fine but heavy white smoke on startup. Unsure of head condition.
- ABS light is on
- Horn/speed control don't work (could be clock spring or severed wire in wheel)
- A/C not working. Compressor good but missing belt and tensioner pully belt is broken in place
- Leaking rear diff
- Exhaust leak at lower flange
I ultimately decided to sell this as is at a lower price so the buyer can have the confidence of their own repairs. I am happy to answer any questions or take pictures but please only serious buyers.
Maintenance done since 2017:
OE knock sensors
OE valve cover gaskets
Refurbed OE injectors
OE lower control arm bushings
OE fan clutch
OE radiator (2 months old)
OE ball joints
Exterior
New 2-stage paint job 202 black
Bushwackers painted to match
ARB Safari snorkel
HID projector kit
LED tail lights
Engine bay
Magnuson supercharger (bought new in 2017)
Custom intake (K&N carb sticker - passes smog)
Optima Dual battery system with National Luna isolator/switch
sPOD touch screen switch
TuffStuff CS144 high output alternator
Aux fuse block
Suspension & Drivetrain
Toytec BOSS performance kit. Remote reservoir front coilovers/rear shocks (new)
(rear shocks still in box)
Total chaos upper control arms (new poly bushings)
Total Chaos Link Kit (upper/lower links + adjustable panhard bar)
OME 861 rear coils
2" body lift
Nitro 4.88 gears (diffs built by nitro in 2017)
35x1250 General Grabber X3 (like new)
17x8.5 VTX Classic wheels (like new)
Armor
Gobi Stealth Rack + ladder (brand new)
Multicolor LED bar, 4 front lights for rack (brand new)
ARB front bumper
Baja Designs LP6 Pro (brand new)
CBI Off road Fab Rear bumper with swingout
3 rotopax 2 gallon gas + locking mount
Interior
Completely redone
All interior trim pieces died black
Cobra remote mount CB radio
New Kicker soundystem, hidden sub, Pioneer head unit
Recaro Sportster GT front seats (brand new)
Custom reupholstery front and rear seats, door inserts, t-case shifter boot
Sound deadended floor, doors, roof
Premium black Essex carpet with mass backing
4" led screen (mounted, not hooked up)
Parts included:
OE steering rack, inner tie rods (brand new in box)
OE outer tie rods (brand new in box)
Poly steering rack bushings (brand new in box)
Replacement CV axle (brand new in box)
CBI Off Road Fab rear skid (new - missing hardware)
Backup camera
To-do list:
Either replace head gasket/new heads if needed or low mileage engine swap
Replace A/C tensioner pulley or compressor (compressor works, bolt is broken)
Finish painting sun visors and install (easy)
Install new rear shocks
Install rear bump stops/spacers
Fix rear axle seal leak
Install rear seat belts (hardware included)
Finish bolting front seats (one bolt per seat, may have to drill through body and secure from underneath)
Replace driver Recaro seatbelt insert bolt (current is loose fitting)
Finish installing rear seat backs (hardware included)
Finish wiring new off road lights
Isolate rear speaker rattle
Fix horn wiring
Secure hidden sub mount (has rattled loose slightly)
Touch up paint on interior panels
Hide wiring underneath carpet
Bolt down CB mount
Sad to see you let it go! I'm gonna miss those iconic shots of it at Windansea or the Gliderport.
My roommate has always loved your truck, I forwarded the ad to him, maybe he'd be interested.
Keep dropping that price to reflect reality of having this 4runner be primo primo. Your asking price reflects what you may have put into it and want back out.
you got a number i might be able to contact you in the future? im in the market but dont know if i should go for it. Motor problems arent my thing, ill be in the san diego area and might be able to check it out.
I knew it looked familiar! Saw it on youtube when i was dreaming about what I want mine to be in 5 years or so. lol
2001ATL
