FS: 2003 SR5 V6 Built - Westchester County, NY
Ohcrymore
More pics here.
Selling my '03 in order to move up to a newer truck. Current odometer reading is 171,500, this is/has been my daily driver for the past 3 years. Mainly highway miles, 2-3 offroad trips a year (I hate mud with a passion and don't abuse the truck offroad as repairs are expensive). Frame/body are both in good shape, little rust present.
Current mods are:
= OME 90000 Nitrocharger shocks paired with new OME 2885 coils in front (2.5" lift)
= Sway bar delete, LR UCA's (upgraded version)
= Bilstein 5100 shocks with Toytech Superflex coils and Wabfab extended sway bar links in rear (2.5" lift)
= RCI Front/Trans/T-Case/Gas steel skids - powdercoated black
= 4xInnovations HREW Sliders (weld-on)
= 1/4" steel reinforced trailing arm mounts (on frame) done by American Tire in Yonkers, NY (fabricating shop)
= Goodyear MT/R 270/70/17LT Load E tires with 15k miles on them (appear new)
= Shrockworks front winch bumper with PIAA yellow fogs
= Retrofitted bi-xenon 4300k HID lights by Lightwerkz with Lifetime LED's in the high beam slots
= BajaRack with Hi-Lift mount
= Rear push bar (from previous owner)
= Extended rear diff breather
= Left and Right side Antenna Mounts from CBI Offroad
= Pioneer Bluetooth/SiriusXM compatible head unit
= Permanently "hot" power outlets
= Weathertech trunk liner
= LED interior lighting
= All-weather mats
= Carbon-ceramic brakes
= Remote start/keyless entry
= Dual 2.1a USB charging ports in center console
Recently replaced/done:
= Radiator
= AC Condenser
= Battery (Toyota, 8 year warranty)
= Starter motor
= Power Steering Pump
= All pulleys
= Water pump
= Alternator
= Rear main seal
= Front trans seal/fluid
= Hood repaired/repainted professionally by Northern Westchester Autobody (due to salt chips)
= LR UCA's (May '16)
= Front coilovers rebuilt, coils swapped from OME 2886 to 2885 for ride quality, new shock mounts installed.
= Windshield replaced under insurance after a Jeep threw a rock into the old one on the highway.
Things that need to be done:
= Exhaust requires rebuilding from the muffler back
= AC Compressor requires replacement (per mechanic, 2.5 hrs work + parts)
All motor/gear/diff oil changes and routine maintenance are up to date, synthetic oil has always been used. The vehicle has been in 2 accidents (1 collision and one due to a faulty part). It was repaired under insurance both times by a professional body shop, there is no damage to the drive train or frame. The truck came with a dent to the rear right quarter panel from the previous owner, it was sprayed with rust retardant when I got the truck and has given me no problems since.
The truck will come with (if you want them):
= Traxx traction aids
= x1 OEM CV axle (intact)
= x1 OEM CV axle (rebuildable, requires a new inner boot)
= Weathertech in-channel window deflectors (new, not installed)
= Front sway bar (not bushings), stock roof rack and stock running boards are also available
While the truck is dirty in the google album pictures, it will be professionally detailed prior to pickup.
Looking for $7,000, obo.
Please feel free to PM/text me with any questions/concerns.
Sam (914) 482-0141
patnewton
