FS 2011 modified 4runner limited, asking 41.9k La Habra, CA
Speedy Babo
FS 2011 modified 4runner limited. Decided to slowly return to mostly stock. Check out the 5th gen for sale items in the future. Planning to sell almost all after market add ons.
Very good condition. Listed most of the major items and work done. Message me if interested and want more details.
Listed on Autotrader:
Autotrader - 4Runner Ad
For sale: Heavily modified 2011 Toyota 4Runner limited w/ full time 4WD. Original owner, in very good condition, well cared for. Lots of upgrades and modifications, can provided detailed list upon request.
Electrical: Odyssey AGM battery with ArcLight triple state voltage booster. Anytime Backup rear camera switch
Lights: Custom LS460 bi-xenon retrofit w/ amber halos in headlights. LED trail edition taillights. Diode Dynamics SS3 Pro amber fog lights. Custom bussman fusebox with extra aux switches available. Switch operated 42in LED front lightbar and rear baja designs LED floods.
Suspension: Kings 2.5 OEM F+R remote resi w/ adjusters. 650lbs springs in front coil overs. Total Chaos UCA. Rear spring is Dobinsons C59-677V variable rate coil w/ custom 27" long travel length on the rear Kings. Brake lines upgraded to Wheelers Offroad SS brakelines, extended length on rears.
Armor: Shrockworks steel front bumper, 5piece skids, straight sliders w/ dimpled tread plate and TE rocker trim. Budbuilt steel rear diff skid. Expedition-one rear dual swing out bumper with ladder, tire carrier, hi-lift mount, and extended rear camera bracket w/ license plate relocation. Southern Style roof rack with full length cross bars.
Wheels: Konig latest generation Countersteer Type X wheel (recently replaced and in perfect condition) in 17" w/ Nitto Ridge Grappler 285/70R17. Includes 2 matching spares (1 undercar and 1 on rear bumper), the spare tires are matching and never been used.
Misc: Has tints. All doors and roof have sound deadener and 3M thinsulate. In 2016, rear ended at low speeds, but it bent the tow hitch and rear crossmember. Serviced at Longo Toyota Collision, had the entire frame replaced with a new OEM frame and OEM parts.
Door handles were painted with color matched paint, but some parts have chipped. Have extra paint that'll be provided.
Latest service: Moonroof rubber seal replaced Mar 2022. Brake pads changed w/ Akebono ceramic pads and front OEM rotors resurfaced Aug 2021. Spark plugs, Passenger side front axle boot ripped and changed with new OEM axle, diff oil change done in Mar 2019. Brake lines changed to SS lines and fluid flushed, water pump, serpentine belt, 2 pulleys, both front lower OEM control arms, coolant flush, and other maintenance done Sept 2019. Total Chaos UCA ball joint and bushings were replaced in 2019.
2001ATL
