FS: 22RE Engine Parts, $5-$650, Olathe CO
torynich
All parts off a 1987 Toyota 22RE. A little back story on the engine: I bought a 4Runner with a knock in the engine. Upon disassembly I discovered that the camshaft went flat due to improper break-in, which in turn took out the rocker arms and oil starved #3 rod which took out the connecting rod and crankshaft. I do not have any documentation on the engine but would guess it only had a couple thousand miles on it. Since it was not feasible to replace the crank, cam, rocker arms, and connecting rod I ordered a replacement overhauled engine. While waiting for the replacement engine, I ordered a bunch of new parts to install the engine. Long story short, the overhaul shop was never able to produce an engine after 6 months so I canceled my order and sourced a core engine to install in the 4runner and sold it. These are the parts I have left over. OBO!. Located in Olathe, Colorado. Respond here or text 970-209-seven three three six.
NO TAX, FREE SHIPPING (CONUS), NO CORE CHARGE!!!!
Injectors: Fresh, Never run, 22RE Type-C Equalized Fuel Injector Set (83-87)(Have Paperwork from LC Engineering) $200.00
Headers: OBX/R Stainless Steel, New Never Installed, EGR Holes Welded Shut. $180.00
Head: As removed, in very nice shape, low mileage. Sold!!!
Intake: New Style, powdercoated Prismatic Black. $50.00
Timing Cover: Powdercoated Prismatic Black. $50.00
Valve Cover: Powdercoated Prismatic Black. $20.00
Oil Pump: As removed. $5.00
Oil Pan: Powdercoated Prismatic Black. $20.00
Distributor: As removed. $50.00
EFI Wiring Harness: As removed, engine portion is complete, but looks hacked to me. $5.00
Cold Start Injector: As removed. $10.00
Toyota Supra 7MGE Throttle Body/Adapter Plate/AFM: As removed. SOLD!
EFI/5-Speed Engine Computer: As removed. $20.00
NGK Spark Plug Wire Set: New, P/N: RC-TX99A. $35.00
NAPA Gold Oil Filter: QTY 2, New, P/N: 1348. $5.00 each
Raybestos Upper Ball Joints: QTY 2, New, P/N: 500-1065B. $15.00 each
Duralast Powersteering Pump: New. $80.00
Denso Oxygen Sensor: New, P/N: 234-1056. $21.00
NGK Spark Plugs (QTY 4): New, P/N: BPR5EY. $11.00
NAPA Cap & Rotor Set: New, P/N: EP671SB/EP687SB. $12.50
GMB Water Pump: New, P/N: 170-1640. $16.00
NAPA Fan Belt: New, P/N: 9440. $18.00
NAPA Fan Belt: New, P/N: 7345. $13.00
Fram Air Filter: New, P/N: CA4830. $10.00
Chevy Alternator Bracket: Powdercoated Silver Vein. Sold!!!
Miscellaneous Engine Brackets and Pulleys: Powdercoated Silver Vein. Entire Lot. $50.00
Front Engine Pulley, Flywheel, Air Conditioning Compressor with bracket & idler pulley, 3 good connecting rods: As removed. $10.00
As typical, I cant figure out how to post pics...go here for pics:
http://s294.photobucket.com/user/tor...?sort=3&page=1
The new style intake, supra throttle body and AFM, EFI wiring harness, EFI computer, and chevy alternator bracket are off the core engine. I never ran these parts and therefore cant vouch for anything except a visual inspection on them.
Jesse1
