carp73
It’s come time to sell my beloved 4Runner I’ve been building for the last several years. Below is a list of everything I have done to it since I bought it stock
243000
Engine rebuild
New wheels and tires
Added 3” toytec/eibach lift (front and rear shocks and springs)
Toytec pan hard drop bracket
Extended sway bar end links front and rear (Moog)
Alignment
New front rotors and pads
New clutch slave cylinder hydraulic soft line
Brake and clutch fluid flush
New OEM knock sensors and harness
New Idle control valve
New post CAT O2 sensor
New hatch struts
Subs, amp and head unit
Hitch mount rear tire carrier
Weathertech in front and cargo area
1” Body lift with two added body mounts
Intake silencer delete
245000
Oil change
New OEM lower ball joints
New CV axles (O’Reilley lifetime warranty)
Thrush welded muffler
ARB bumper with winch (welded in frame end caps)
Off road lights
Painted grill and rear bumper
CB and antenna
Sliders
248000
Oil change (Mobile 1 XP full synthetic with WIX synthetic filter)
Front and rear diff and T case oil change (redline synthetic 75w90)
Transmission oil change (redline synthetic MT 90)
New air filter
Grease drive shafts
New windshield wipers
Replaced leaking passenger side rear shock
249000
Toytec rear differential extended breather
Toytec 3” bump stop extensions
Rear axle seals
Rear wheel bearings
Rear brake shoes
Toytec braided front and rear extended brake lines
Tire rotation
254000
7 pin trailer harness and brake controller installed
255000
Oil and filter change Castrol full synthetic 5w-30
Air filter change
Re-gear front and rear to 5.29 with new ECGS third members
Front wheel bearings and seals
Tacoma manual hub swap
256000
SPC Light Racing upper control arms
Alignment
5x 315/75r16 Cooper Discoverer STT Pros
Fresh gear oil front and rear diffs Lucas 85W-140
Rebuilt stock front CVs
Sonoran Steel solid rear body mounts
4x Innovations skid plate
4x Innovations rear bumper with tire carrier
OME 861 rear springs
Switch off road driving lights to yellow
Install auxiliary reverse lights in bumper
New trailer wiring harness and controller
259000
Tire rotation spare to left rear
New headlights
Removed front sway bar
Installed scangauge
Installed supercharger
Installed wide band AFR and boost gauge
Installed Denso IK22 iridium spark plugs gapped to .032”
Install new 190 LPH fuel pump
Install URD 7th injector and controller
Install URD 2.2” pulley
243000
Engine rebuild
Alignment
New hatch struts
245000
Oil change
Off road lights
CB and antenna
Sliders
248000
New air filter
Grease drive shafts
249000
Rear axle seals
Rear wheel bearings
Rear brake shoes
Tire rotation
254000
255000
Air filter change
256000
Alignment
259000
New headlights
Installed scangauge
