FS: 2nd Gen 95 4runner sr5 4x4 auto
jclary2987
For sale is my 1995 Toyota 4runner with 225k miles. It is an SR5, 4wd, with the 3.0 V6 and an automatic transmission. Power windows, sunroof, a decent aftermarket stereo and speakers that sounds great. Freshly tinted windows. For its age the paint and interior of this 2nd gen 4runner is in excellent condition. This is by far the cleanest mid 90's 4runner that I have been around, no rust, all stock, never been molested or mudded. It spent most of its life as a grocery getter in Dallas. Before we installed the all terrain tires it wore highway radials to give you a feel of how pampered this vehicle had been. We have cared for it with the mind set of getting another 200k miles out of it so everything is in good working order. If I was to keep it there are a few things that I would address, most of which are cosmetic. The dash has some cracks in it but what 95 doesn't, so I would replace dash pad, replace steering column cover, replace sunroof switch cover, and replace passenger side window switch (intermittent problem). Below is a list of things we have done to maintain and extend the life of this 4runner, all done in the last 6 months.
Engine
-regular oil change and filter
-replaced timing belt
-replaced water pump
-replaced wires and plugs
-replaced fuel injectors
-replaced valve cover seals
-replaced front cam shaft seals
-replaced pcv valve
-replaced fuel regulator
-confirmed that head gasket was replaced earlier in life via Toyota recall
-had technician check compression on all cylinders
-had technician check valve clearance
Transmission
-changed fluids
Suspension
-replaced old sagging rear springs
-replaced all 4 shocks
-replaced rubbers on sway bar
Brakes
-rebuilt rear drum brakes with new shoes, drums, master cylinder, hoses
-replaced front brake pads
Tires
-General Grapper AT2 (less than 8k miles)
-rotated and balanced recently
Also have the original running boards that will be included with sale.
Clean Texas Title
$5,000.00 or best offer
I'd like this 4runner to go to someone who would appreciate it. It is a bone stock blank slate that will make someone very happy.
This is not a deer lease buggy or a mud truck so low ball offer will not be entertained.
AndiGarage
