FS: 3rd GEN - 97' 4runner limited, $3000 OBO, Orange County, CA.
Shampooo
Hey guys, I am selling this 4runner because I wanted to treat myself after graduation and upgrade to a newer Tacoma. I have used this 4runner as my daily commute to school for the past 5 years.
97 toyota 4runner Limited
166k original miles
Clean title
Fully loaded
4x4
passes smog
Tags are renewed
Bough 4runner with 134k miles. List of services and mods since:
-Replaced radiator (Denso)
-Coolant flush with Dexcool
-Transmission, transfer, and diff oil change
-Spark plug, wire, and grommet replaced
-Separated transmission cooling system from radiator and installed Transmission oil cooler
-Timing belt, and front end service
-13WL (231mm) tundra font brake upgrade
-3" tundra front spring upgrade
-3" front diff drop
-CV axle and boot replaced
-5" Landcrusier Rear spring (9 spring coil) upgrade
-Front and rear Bilstein 5100 shock absorber upgrade
-Toyo Open Country all teraain 2 with approx 30k miles
-Speaker upgrade
-subwoofer hook-up
Cons:
-Driver side door lock does not work. Unlocks through the passenger side
-Interior and exterior cosmestic damage; wear and tear
-previous owner had the 4runner painted black; original color is white
-previous owner welded the front sway bar bolt onto the frame and tried to cut through them, missing rear sway bar and no endlinks
-Muffler needs to be replaced
Pros:
-All power windows, sunroof, rear window still works
-lifted with barely used tires and full treads
-no leaks, 4x4 still works
-new catalytic converter
-a/c blows cold
4runner still runs like a champ. Great commuter vehicle with low mileage for its year. I have had no issues with it.
Pricing lower than I should because I would like to sell it to someone who would appreciate this 4runner.
Continue...
patnewton
