SantaCruzRunner
Senior Member
Have some daystar spacers laying around I thought id sell. 3 inch spacers in the rear and top plates on the front struts. Good shape, not used very long. Asking $75.
If you plan to post to Classified forums, you must follow these rules, or your post will be deleted.
Thanks Connor for the heads up.
What's the details of this front setup? Brand Coils and struts? Lift height? Also, how in the world do you mount these and still have enough thread on the top studs with the spacers? Seems kinda unsafe.
I knew those thicker ones were for the rear but looking at the assembled front it looks like there would be barely any threads left on the studs to bolt up. Maybe they're just not sitting flat in the picture. I also have no idea how the preload spacers work in conjunction with the those top spacers. Maybe I'm confused here lol
Yea, I don't know if that's going to be tall enough. Only being 2.5" plus the weight up front from my armor will make it more like 2" when it's all said and done. I'm trying to avoid having to pull the grinder out for temporary clearance.
On full compression, with your current setup, it would rub anyways if you have to pull the grinder out for 2.5"
Do you rub when wheelin? If not them you should be good.
