FS 3rd Gen lift parts - CO & AZ
111db
ALL ITEMS ARE SOLD, THANK YOU
I have various suspension parts available off my 97 4Runner. From my AZ truck - no corrosion. Currently located in Trinidad Colorado. Can deliver to Phoenix area toward the end of September. PM me if interested. thanks.
FRONT
  • Tundra coil springs
    2004 TRD Tundra 4WD front
    48131-AF090 Passenger side (blue & yellow)
    48131-AF100 Driver side (yellow & yellow)​
  • 1/2" lift top spacer plates (not diff drop)
  • extended 38mm studs
  • stock 4Runner mounting plates
These were from the Sonoran Steel 1 (1.2) kit, all you need are new shocks (currently have old Tokico's installed - you'll need to remove them). Very good condition, they have less than 10k miles on them. Lots of life left. Will get you 2.5"-3" lift depending on your vehicle & its weight.
from Sonoran Steel's site:
USED COILS:
99% of them used out there will not work. Nothing from an Access Cab will work, Nothing from a 2WD will work, Nothing from a NON-TRD truck will work, Nothing from 1999-2002 and 2005-2006 will work. The only coil that works and is tall and soft is 2003-2004 Full 4 Door Double Cab, 4WD with TRD Package. The coils have the color codes Yellow-Yellow and Yellow-Blue.
Rear:
  • LC80 coil springs.
1995 FZJ-80 front
48131-6A570 Passenger (Purple/gray/white)
48131-6A480 Driver Side (Green/orange/white)​
Still installed - will remove when I have a buyer. Approx 20k on them, I'll be happy to take a lift measurement for anyone interested
utkrstam
