FS: 3rd Gen Performance Camshafts - Sacramento, CA $400
gamefreakgc
Elite Member
For sale for $400 is a set of Colt Cams 5VZ-FE camshafts with extra shims and shim spacers. These are regrind camshafts that add extra lift on the intake side as well as optimize flow for a supercharged or turbocharged 5VZ-FE. I am willing to ship the camshafts, just a note that they are heavy. From owner, Geoff:
We do offer a mild perf. grind that gained 22 HP
INT: 262° .347L
EXH:264° .330L
They will come with extra shims and shim spacers, minus one spacer on the intake side due to damage. I highly recommend installing stiffer valve springs like these from LCE as the stock springs will not handle the extra lift very well: Street Performer Valve Spring Set(24) - 5VZ. It may also be good to skip the spacers and order new valve shims of the thickness of the shim and the spacer combined. There is slight damage on one of the lobes of the intake camshaft.
Post here if you have any questions about either as I would suspect that if you are interested in the camshafts you'll have questions.
wwarren702
