FS: 3rd gen projector retrofit headlights- $250obo, St. Louis, MO
NJCatalana
I'm selling a set of projector retrofit headlights that I bought a few months ago, but am getting a different set. The passengers side headlight is stuck on bright, and I do not have the patience to go back and fix it, so I am selling these to buy another set. I've heard it could be a problem with the projector, or just a ballast problem. I'm asking $200 plus shipping OBO. The wiring harness will not be included, but the headlights, bulbs, projectors, everything else will. All you'll need is a wiring harness and its plug and play for there. Feel free to ask any questions or info, or shoot me an offer, thanks.
If these are the TRS projectors there is no "high/low" from the ballasts. The "high" setting is just movement of the cut off shield and allows the majority of the lens to project the light from the bulb. The bulbs are constant state, nothing changes on the electrical side other than the cutoff moving. You might just need to check your plug to the shield if this is the case to see if its shorting or the shield just might be stuck up.
If they are not TRS and some other set up, then all can be disregarded.
Interesting, thanks for the input guys! Unfortunately I already ordered the new set. No these were not TRS projectors, unfortunately. So of anyone is curious this seems to be an easy fix!
sounds like a good deal.
as others have said ballast don't have a high low feature in most cases.
I have had the TRS Morrimoto ballasts and the OEM Denso ballasts. Both just supply clean stable power and the high low is either A) the bulb or B) the projector moving mechanically
