FS: 4th/5th Gen Eibach Pro-Truck Shocks $180.00 Denver
sn0wrunner
I have a brand new set of Eibach Pro-Truck shocks for 4th/5th gens for sale. Provides 0-2.5" of lift with stock springs. Price is $180.00 shipped to anywhere in the lower 48. $160.00 for local pickup.
My daughter has a 2006 2wd would she just need to get springs? Or use stock springs
Sent from my Pixel 2 using Tapatalk
Either or.
They are designed to work with the factory springs, but you could use springs like these and they would work fine. In the first photo you can see the 4 grooves in the shock body for the c-clip to mount the spring perch. If you use stock springs you'd want it set on the top setting, if you use an aftermarket spring like the one in the link below you would want it on one of the bottom two settings.
https://www.toyteclifts.com/112-620-p-toytec-eibach-front-coil-lift-springs.html
bluelinepilot
