FS:5th Gen 4R King Coils And Shocks ext travle comp adjust,$2400 San Luis Obispo,CA
theway131
FS:5th Gen 4R Rear Shocks ext travle comp adjust,$820 shipped San Luis Obispo,CA
SOLDThese coils and shocks off my 2015 4runner have 5000 miles on them and are the extended travel version. They have clicker adjuster both front and rear. They are in good shape and won't need servicing for a long time to come. There are no leaks or damaged seals. New these cost $1021.00 with tax not including the shipping and 5 week wait time. These fit 4urunners and Fj's as well.
Jonathan
Price: $820 shipped
Here are the king part numbers KRS-25001-279A KRS-25001-278A. I'd check around just to be sure, but yes I believe they will fit your rig. Perhaps call king or one of there distributors or check on the forums. I'm under the impression that the 4th and 5th gen is the same truck just new cab. I may be wrong though.
Kings
So I called king and down south motor sports, It seems that the revi mounts are different but the shocks fit. You would have to either order the correct resi mount or get an after market one like the ones like these SYNERGY MANUFACTURING*::*Shock Mounts & Kits*::*Remote Reservoir*::*Synergy Shock Reservoir Mounts For Dodge 1500, 2500, 3500 4x4 and custom mount them. The hose for the resi may also have to be re-clocked, depending on where you decide to mount them. This can be done easily by pressurizing the resi and loosening the hose, moving it to the correct position, re tightening it and re-charging the resi.
Will these fit a 4th gen?
David, just so you know, you can run these without getting the long travel kit. they will fit your truck (except for the remote mounts).
The are the best of the best coil-overs. I do see some pretty good sand blasting on the heims, but the shafts do not look pitted.
But you can mount the resi with an aftermarket bracket on the frame rail. The shafts are in pretty good condition although they do have a few dings that could use a little emery cloth buffing, the seals aren't leaking either.
4Runna4Rumma
