FS: 5th Gen 4Runner Durobumps Bump Stops F&R $203.00 Tuscon AZ
Plastics guy
Front and Rear set of Plastic guys 5th Gen 4Runner Durobumps.
Durobumps eliminate the hard bottom outs we're all familiar with on hard hits or crowned intersections when contacting the rock hard OEM bump stops.
Durobumps are the only Dual Durometer (hardness) bump stops and we are the only manufacturer building application specific products. No one size fits all approach and no spacers.
We eliminate shell-shock on hard hits, we increase vehicle stability, and we do it at a fair price
FRONT DUROBUMPS SET
Front bump stops made of dual durometer rubber. they are slightly taller than OEM bump stops but compress under load to the same height as OEM. These bump stops make a immediate noticeable difference on the trail and you will even notice an improvement while daily driving.
REAR DUROBUMPS SET 4.5"
Not only is the rear OEM bump stop height to short for lifted trucks, As many of you know there is also a Toyota Factory design flaw with the rear OEM bump stop. it is not centered over the axle. Our Rear Durobumps are 4.5" in height to work with lifted trucks of 2"+ and our bump stops are offset to address Toyota's design flaw and make better contact the axle tube.
You can read about all the details here www.toyotabumpstops.com
Price $203.00 with free shipping (everything you see in the picture 2 front Durobumps, 2 Rear 4.5" Durobumps. including all mounting hardware)
