FS 5th Gen. Full Length Roof Racks by drabbits
Wired the roof rack...
Pretty standard path through the inside...then pulled up thought the existing rubber grommet/seal and up into the driver's side roof rack channel.
Pics...
Does this mean your light bar is on and the next question is for the picture of course? Can't wait to see it.
Awesome, I almost started a new thread on wiring, but this is so clean. What gauge wiring did you run? And I'm assuming it's both hot and gnd in the loom?
Yes...both hot and ground all the way from the driver's side (hot from the engine - painless 7 connection) and ground at the bracket under the switches.
I used 14 gauge stranded. Bought the grab bag of rubber grommets (all from Home Depot) which fit 3/8" perfectly.
Drilled both holes @ 3/8", basically wanted the rear hole just in front of the mount so the wiring would be firmly in place as it ran between the bolts under the rack mount - there is just enough space there. And drilled the front just after the curve but before the center as there is reinforcement in the tubing and wasn't sure I could get the wire cleanly through that section. I just used some thin non-insulated solid wire to fish the wire through. It actually worked out really nice.
LOL...haven't bought the light bar yet...it is amazing how long it takes these shops (retailers) to return email on just the dimensions. I am ready to pull the trigger now...but just sitting on my hands waiting for simple thing like the specs so I can buy the correct size.
I am probably going to get a 30" as the 40" simply will not fit as I only have 38" of space on top since I have a-pillars added to the rack. I bought some a-pillar mounts to test but that takes me to 40" exactly and the bars are about 42" w/mounts - it will also sit too high up for the garage door so need to go low profile.
I can take a pic with my old PIAA fog up there...lol. It will be the cyclops look!
[MENTION=50210]KVA[/MENTION]
What about some universal tube mounts and mount it to the top bar but hanging down... not sure how much space you have on the outside of the a pillars.
This is just an example...
Looked at those but they didn't look like they would work - they were my first thought though. I bought some rigid a-pillar mounts to test and unfortunately the angle isn't 45 degrees (not that big of a deal) so they aren't a great match either. The biggest issue is the a-pillars blocking the path for the led bar.
I was thinking the light bar would have to sit in front / on top of the a-pillars.
Were you still considering BlackBox?
Yes - have been talking to those guys and really like the H series. If I can get the dimensions I will pull the trigger. Would love a 40" but it will be tough to clear my garage door with the added inches above the rack. Once i get the specs I will measure again. Decision, decisions...that is why I pre-wired...everything is easy now.
I'll wait for a real picture thanks, but appreciate the wiring pics!
These are the flavors I've been looking at. I am hoping to pull the trigger on one in the next couple of weeks. (these are in order of my preference)
I'm open to any input anyone has on any of these bars. (or others)
The Retrofit Source MORIMOTO X.BAR 40" $1,000
Morimoto X.BAR 40 - Off-Road Lighting
Rigid Industries SR2 40" - Combo $1199
Rigid Industries LED Lighting | Leader in Off road LED light bars, truck LED lights, Marine LEDs, and Industrial LEDs
VisionX Evo Prime 39" $1,749
LED, HID, and Halogen Lighting | Off Road Lighting | Offroad LED Lighting | Mine Lighting | Mining Lighting | Marine Lighting | Agriculture Lighting | Defense Lighting | Industrial Lighting | Commercial Lighting | Automotive Lighting
Black Box Logistics H Series 40" $399
Black Box Logistics - H Series
(link is to the 30" bar, they dont list the 40 on their site)
Were you able to find any pictures of that Morimoto X.Bar mounted? Looks awesome but I'm somewhat confused as to how tall it is and having trouble envisioning it...
They don't have them for sale yet. But I did find out that they worked with a company called Heretic Studios to design these. Check out their site for a some pictures.
Hopefully by the end of the month TRS will have something.
Edit: Just realized TRS changed the pricing... Boo. 40" bar went from $1000 to $1200
Got it, thanks. Yeah I also saw it went up in price. Looks rad though and I'm a fan of that Heretic's stuff...
I have respect for you now...it is very time consuming to work with aluminum.
LOL This came to mind when I read that,
RodneyDangerfield_zps93cf790d.jpg~original
What does a man need to do to get some respect?? haha,
I can send you some steel to bend up next...lol
Thanks man, means a lot coming from you, considering your responsibilities!
Yeah I'm kind of torn between the single LED bar or breaking up the space with multiple lights. Wiring would be more complicated but I kind of like the look better... I've been looking at what other folks have on their gobis while I anxiously await my rack to get fabbed haha
IMHO, I personally think the one piece light bar looks better, a bit more intimidating.
Here's a 3rd Gen rack I built for [MENTION=91297]Kraze[/MENTION] that has a 36"? bar.
Kraze001_zps1e4d76c8.jpg~original
Making a 40" bar work will depend on the way the light bar mounts, some have large side brackets and some have brackets that kinda tuck under the bar.
Here's one that has mounting brackets beneath the bar..
40" Off Road LED Light Bar with Spot/Flood Combo Beam - 120W | LED Work Light & Off Road LED Light Bars | Super Bright LEDs
BUT, I have also been toying with the idea of a 20" bar in the center and two 8-10" bars on the sides, slightly angled out.
Hope I didn't make your decision harder..:biggrin2:
One big light bar is easier/faster to steal then multiple lights, the time it would take to get several small lights might help deter theft. But yeah the one big light bar going all the way across just looks bad@55.
[MENTION=50210]KVA[/MENTION] Nice work on the wiring, can't wait to see what you end up with!
[MENTION=91899]Jhalko[/MENTION] Not trying to be funny here, any chance of the alarm going off if someone tried to steal the light bar? Or wiring in some sort of constant that would trigger the alarm if cut?
[MENTION=91899]Jhalko[/MENTION] Not trying to be funny here, any chance of the alarm going off if someone tried to steal the light bar? Or wiring in some sort of constant that would trigger the alarm if cut?[/QUOTE]
Well I set the darn alarm off about every other week with the keys in my pocket, but that s from the panic button. I've never climbed on the truck while it was all locked up, with my luck I could jump on the running boards on it and it wouldn't make a peep. Someone with far more knowledge then me might have a solution but seems like security bolts are what most folks use.
I need to have a chat with my wife to make her feel like she had input on ordering a rack so I can move on to figuring out what lights I want up there anyway, hahaha.
charlesz
