FS: 5VZ Supercharged drop out drivetrain with custom exhaust, $4k VA
robb1887
The stars finally aligned and I picked up a 2006 Tundra V8 4WD donor with 63k on the clock this past weekend. What that means is that in the following weeks my current 3rd Gen 4Runner setup will be completely for sale. I’m posting it early in hopes that the new owner will have a chance to see it in person prior to purchase. All parts will be pulled and require to be picked up as once I pull it I won’t have anything to deliver it in.
Setup:
Rebuilt 1st Gen TRD SC
TRD Long tube headers
Custom 2.5" Stainless Midpipe
Modified 2.5" Gibson Stainless Cat-back
Overhaul/tuned up 5VZ
Original Trans
Original Transfer case
B&M Trans cooler
Asking price: $4000 for everything
Details:
Supercharger: ~7K miles
Sourced locally from the original owner (dealer installed) with 100K+ on it, it got broken down to full parade rest and rebuilt with new SKG bearings new sealant.
Nose cone modified for oil change while installed
Dynamic TRD tensioner kit
7K OEM SC belt
Denso 5310 spark plugs
NEW OEM SC belt spare
Original box and packaging/paperwork
ALL original parts save for some misc vacuum hoses I replaced
I cut the static pulley bracket to originally install the "nose support bracket" but never saw the need to put it on but is included
Exhaust: ~10300 miles
TRD Long tube Headers (Non-EGR)
Headers and Y-pipe Ceramic Coated
2.5" SS Flex joint
Vibrant 7101 Cat
Vibrant 1792 Resonator
Gibson 2.5" Cat-back
V-band clamps past headers (pre cat, post cat, post muffler)
2.5” SS ppg
"Defeated" post cat O2 with no check engine light
New Denso 234-4209 Pre-cat O2 when installed
Extra bung for Wideband or whatever installed pre-cat
Starter heat shield will be included
All joints are TIG welded
Original Box and paperwork
Motor: 186300 miles
Original motor to the truck had a knock I couldn't fix/find. I had a known GOOD motor with 176xxx miles that I had from a '01 parts truck.
Before I swapped the following was replaced:
Timing belt/water pump kit
Front & Rear main seal
Oil pan Sealant
Existing oil pump with new O-ring/sealant
Idler pulley
Tensioner pulley
Motor mounts
VCGs
Manifold Gaskets
Pulley/Fan bracket/bearing assembly
New plug wires ~5k miles
Currently have ~10300 miles with zero issues
Mobil1 is all this motor has seen in my possession.
Transmission/Transfer case: ~208500 miles
Original to the truck (1997)
I purchased in May of 2011 and have maintained them since.
Transfer case has recent fluid change with Amsoil fluid
Trans had the B&M external cooler installed late 2011 and has had OEM Toyota fluid
I purchased the TransGo performance shift kit and new gaskets to install but haven’t had the chance to put it in yet.
VB gaskets, Oil pan gaskets, and pickup filter/parts were purchased to go in with the TransGo kit that will be included if I can find them in the garage after our move.
Engine & trans/transfer case will come with full harness and Motor ECM.
Seperation pricing:
SC alone: $1800
Headers alone: $1100
Header back exhaust: $1200
Full exhaust: $2100
SC + exhaust: $3500
SC + headers: $2700
Drivetrain alone: $1000
See post #8 for details
Extras that will be thrown in at asking price:
Used 96 front and rear driveshaft (I’m keeping my originals)
Used 01 transfer case
Used 98 trans
Used 98 torque converter
Original Intake runners
I’d like to sell everything together obviously, but am willing to separate if I have buyers for each respective part. I can take any photo you’d like and video of cold starts, pulls from a dig or whatever else anyone would like to see.
I'm in the middle of a shed build so the work will not start until I've completed it which I hope to be in 2 weeks as long as the siding and shingles aren't long lead time but I wanted to post early to gather interest to allow schedules to align to come check it out.
Work computer doesn't like forum code so I can't embed the photos I have at the moment. I'll fix this when I get a moment at home. Any additional/particular photos can be taken and uploaded on request.
TRD SC rebuilt by R Mo, on Flickr
TRD SC installed by R Mo, on Flickr
Custom Exhaust by R Mo, on Flickr
Coated TRD headers by R Mo, on Flickr
2.5" SS Flex joint
Vibrant 7101 Cat
2.5” SS ppg
That exhaust!!! :wow: :thumb:
Very nice, well thought out setup... free bump!
How much for the complete exhaust shipped to 64870? (If you're willing to separate).
Still holding off to separate, but will keep you in mind for the exhaust if I have buyers for the SC and drop out.
Thanks, BFAD it could be yours....
My drivetrain is about the same as what you're selling, so I would be in the same boat as the other guy, looking for just the exhaust. I have headers as well, so I'd be looking at the system from the headers back.
I'll keep an eye on the thread to see if you decide to separate things.
Depending on price, I'd be interested in the headers...
"Separation pricing"
I havent gotten any bites on the "full package" and plenty of people asking for separate pricing or what not. I'm not liking the idea of piece mealing the sale and getting stuck with the drive train, but it seems like I might have to. With that in mind the following prices (updated in the OP as well) will be the asking prices(+ shipping costs):
I will ONLY separate after I get deposits (20%) for each of the "big" pieces (minus the drivetrain)
SC alone: $1800
Includes:
Original box and paperwork, all original parts with the FPR and new oring, with all needed vacuum lines to install.
OEM Dynamic tensioner kit
Currently installed belt
Spare OEM belt
Includes:
Original header's box and paperwork
TRD headers
Collector and flex pipe with ppg cut just after flex and before first V-band
Includes:
Exhaust ppg cut between flex pipe and first v-band
Everything else from the exhaust Cat to Gibson tip.
Full exhaust: $2100
Includes:
All header alone & header back items (uncut)
SC + exhaust: $3500
All "SC alone" items
All "Full exhaust" items
SC + headers: $2700
Includes:
All "Headers alone" items
Includes:
Motor, Trans, Transfer case, Harness, ECU, Trans cooler
I will take deposits after I have solid interest for the "big 3" SC, headers, and HB exhaust in whatever configuration the buyer(s) likes.
"Full exhaust: $2100 Includes: All header alone & header back items (uncut)"
Just priced new online @ Burtman Industries & Vibrant ... can purchase new (granted Doug Thorley cermaic coated headers and not TRD) for $2100 +/-. 100k + miles on the exhaust system.... how firm are you on your price?
DT SHORT tube headers: $700
Vibrant bungs: $15
Vibrant V-bands: $65x3 = $195
Vibrant Res: $45
Vibrant Cat: $110
Gibson Exhaust: $485
Denso O2 front: $50
Denso O2 rear (defeated to not throw code): $50
Flex pipe: $20
Welding/fitup: At a shop $250? ball park
Misc ppg bends & tube: $100
Starter shield: $30
Misc hanger/bung plug/new hangers material: $100
Total: $2150
That doesn't take into account:
TRD LONG tube headers that are unobtainable
Plug and Play application with no CEL
Lead time (weeks for the Gibson and DT headers when I was doing my shopping).
This is a direct bolt on kit that only will require a new gasket set for the headers (Remflex 7013, btw). And maybe some metal zip ties (if I can't get them off cleanly) for the starter blanket that is optional.
Gibson exhausts come with slip fit and u-bolt clamps which I did not see at satisfactory so all the ppg pieces were cut and welded together with strategically placed v-bands for disassembly. The V-bands also required no gaskets so after the last header flange (bottom of the y-pipe) the exhaust can be removed with a couple of box wrenches without needing new gaskets.
I expect its a typo, but clarification there is only 10k miles not 100k.
So I figure my pricing is pretty fair considering the factors, but I'm open to offers. The worst I can say is no.
To be clear, I don't think your pricing is unfair.
When I said "too rich for my blood", I meant that unfortunately my own finances won't allow it... I'm too broke for a setup that nice at the moment.
Seriously, one of the nicest exhaust setups I've ever seen for these rigs.
man i really need the SC, i wish there was a way to put it on the credit card lol. Free bump, GL with the sale. thats a hell of a setup!
Since I can't get people to buy in on a whole package I will likely be selling the headers and SC individually and grafting the exhaust into the 2UZ swap.
I'll post separate threads when they are ready to go to their new homes.
Ambrose67
