FS: $6,000 1st GEN 2001 Tacoma TRD-4x4-5spd in San Antonio, TX
ZigRig
Located in San Antonio, TX
2001 Toyota Tacoma with the TRD package, a 5-speed manual transmission, and 4X4(w/e-locker)
Mileage: 332,XXX
Clean Title
2nd Owner(Arizona & Texas)
Stock Condition
txt or call: five won too seven seven five too won four eight
Add-ons:
Billet Grill, Tonneau Cover with bike rack&basket, 2-din stereo receiver with CD/Bluetooth/MP3/Aux/USB(wired for a subwoofer)
The Awesome:
Maintained meticulously(I have receipts)
Stock 3"lift(Toytec-TRD)
A/C and Heater work perfectly
Clutch replaced in 2015(OEM)
Lower and Upper ball joints replaced in 2016(OEM)
Inner and outer tie rods replaced in 2016(OEM)
Front Axles replaced in 2016(NAPA with lifetime warranty) I still have the originals and will include in sale.
Carrier Bearing aka pillow block replaced in 2014(OEM)
Brakes replaced in 2017(Wagner)
Gearboxes serviced in 2016(Mobil-1)
Fuel sending unit replaced in 2017(OEM)
Timing belt and water pump replaced in 2016(OEM)
Alternator replaced in 2018(Ultima with lifetime warranty) I still have the original and will include in sale.
Battery replaced in 2017(Everstart)
Spark plugs replaced every 30k(Denso)
Spark plug wires and coil packs replaced in 2016(OEM)
Radiator replaced in 2018(Denso) Due to a minor crack in the top of the old one. Never overheated.
Both Catalytic Converters replaced in 2016(forgot brand-something good)
O2 sensors replaced in 2016(Bosch)
All vacuum hoses replaced in 2018.
There is a passive starter kill switch (aka valet button) installed. This is a great anti-theft device.
Rhino-lined bed
Oil changes done EVERY 3,000miles with (Pennzoil Platinum High Mileage 10w30)
Interior and Exterior door handles replaced in 2018(OEM)
Interior is very clean, with only one tear in the driver's seat(see pic)
This truck runs and sounds amazing. No smoke, no noises, no leaks(other than the minor valve cover gasket).
Rust-free
The Not-So-Awesome:
Needs new shocks and springs. Shock absorber bushings are worn out, so it squeaks quite a bit and is kind of rough on the bumps.
Valve cover leaks a TINY bit of oil. I will include a Beck-Arnley replacement kit which includes the spark plug bushings.
The truck was involved in a minor fender-bender, where it damaged the bumper, bumper reinforcement, and grill. I replaced the bumper, bumper reinforcement, and grill, but it could use a new headlight because the mounting bracket on the headlight housing is broken.
Clear-coat is gone on the hood and in other areas(see pics)
Minor Hail Damage(see pics)
Billet grill needs some adjustment to be perfect(see pic)
Check Engine Light is on due to code: PO402(EGR Excessive Flow) I haven't had time to mess with this, but it doesn't seem to effect driveability. This truck averages 18mpg around town, 20mpg on the highway. Starts up strong, runs strong.
***PRICE REDUCED DUE TO CHANGE IN RIMS&TIRES (the ones in the pictures are not on there any more. Instead, I replaced them with stock 3rd Gen 4Runner rims with Nexen AT rubber)
Craigslist link with more pics:
https://sanantonio.craigslist.org/cto/d/2001-toyota-tacoma-sport-sr5/6675889803.html
H.Sikina
