FS: 96 SR5 3rd Gen VA BCH, VA $5,500
4Runn1nYota
Selling my 1996 4Runner 4x4 3.4 V6. Body Mileage is 205K Miles, Motor Replaced with 50K miles on it when body had 164K, So Motor now has about 91K miles give or take. Everything Runs Perfect, Works Perfect, only major issues it has would be the Exterior Body/Paint, and cracked windshield. Underneath is very reasonable with minor rust. I have protected the underbody with Rust Protecting Enamel Paint last year; have not re-sprayed, since selling, to show sellers what it looks like. It’s not a mall crawler, it’s not perfect, and it's def not a show Runner, but it is a fun ride, great on trails, and ready to go wheeling, Camping, or a daily driver, that won't leave you stranded. I have the Carfax, and other papers of mods with me. Asking $5,500 obo. Here are some Photos and Mods List, of what I can remember doing to it.
4runner - Google Photos
1996 Toyota 4Runner
SUSPENSION (completed est. 5/2018)
Bilstein 5100 Lift Kit 3” Front & Rear from Wheelers Off-Road, T1 Coil Springs Front, OME 2906 Coil Springs Back, OME Trim Packer, Upper Stem Washer, Upper and Lower Stem Cushion, Polyurethane Top Place Spacer, Etc.
Diff Drop From Wheelers
17” Lexus GX470 Wheels, with Firestone Destination AT Tires. 265x70x17 (or 32 eq.)
Mechanical
Driver and Passenger CV Axles Replaced ( est. install 2018)
Driver Passenger New Calipers installed, Breaks, Rotors in ( est. install 2019)
Rear Brakes Replaced ( est. install 2019)
Upgraded Radio Antenna to a Taco Antenna Assembly with a 15” Antenna. (installed2020)
Rack and Pinion Bushings (replaced 2019)
CARGO
Arksen 64” Roof Rack Cargo (extension added)
4ft Firestik Tunable CB Antenna, W/ Heavy Duty SS Antenna Spring and Door Jamb Mount, 18’ Coaxial CB Cable (under Carpet) (CB Radio Not Included) (connection is in Glove Box)
LIGHTING
4” LED Front Bumper and Back Bumper POD Lights, Connect to Switch inside Driver Side. (Back LED PODS work on an ON-OFF-ON Switch. Down is On only when Reverse, Middle is off, Switch up is Always on)
6” Roof Rack LED Side Lights
Front Turn Signal Lights, Converted to Clear Lenses, and have 1157 LED Switchback Bulbs. 1156 replaced with 1157 LED Socket Holders. White when Parking Lamp is on, Turn signal Makes them Amber. Rear Lights LED
LED Turn Signal Flasher Installed (Slows Down Turn Signals)
96 Headlamps upgraded to 99 Headlamps, with LED CAR ROVER 10,000Lumens 6K High/Low Beam Bulbs.
Interior bright white LED, MAP LAMP, Instrument Cluster, Key Ignition Lamp, Shifter, AC, etc.
Interior
99 Console Swap (The Cup Holder Console), Including E-break Assembly (rear heat button also works on the console swap)
Dash Swap, to a 99 Dash, Relocation of ECT Button, Up/Dwn Rear Window, Defroster, Hazard, Clock. (ALL WORK, even the clock)
99 Dash comes with extra Cig Lighter Sockets, One is connected when Key is on ACC mode, the other is wired, but not connected. Was going to do a Straight from battery Connection, just never did, the wire is behind the Dash.
Kenwood DD Radio, with USB plug driver side by E-Break/Carpet
Replaced Blower Motor Fan (est. 2019)
Carpet was replaced back in 2016, However, never did finish the rear where it should attach to the seats. I just attached them to the Headrest Holes.
** I have extra parts I am going to be adding to the sale also:
NGK Spark Plug Wire Set (NEW)
Used, in New condition, Window Deflectors
Extra Used belts
The rest of the parts I had for the interior swap from 96 to 99, ended up selling. Didn't think I would sell my 3rd gen. :/
2001ATL
