FS: eimkeith PCK® (Panhard Correction Kits) for 3rd gen $93.50, 4th/5th Gen $98.20
PM sent. I definitely want to order one! Been researching panhard brackets for a while and yours seem like the best design by far.
Thanks - it's been a community effort, really.
I'm in the mountains with limited phone & internet this week, but I'll be back and shipping kits on Monday. Just send me your name, email, and shipping address for the PayPal request in the meantime.
Must've been a bunch of you guys in the mountains in your 3rd gens over the 4th; - I'm sending out 5 kits tomorrow!
:party:
thanks guys.
Parts received very fast and good quality.
You should consider including extra two bolts, nuts, and washers on future orders. Save me from trying to figure out what is needed and a trip to the store. Wouldn't cost much.
Just use the factory hardware - no need to go to the store! :)
Derp
I looked at a photo I swear had original bolts plus welded. Then two more bolts in the brackets. Clearly that's not how ya do it. I'll find out soon enough if my lc coils would ever show up.
You just need to use the original bolt for positioning on the drop bracket, then tack it, remove the bolt and weld it; the lift bracket should be fairly self-aligning, you may need to spread the top of it a bit after you tack it in position prior to final welding (it's thick material, hard to precision-bend on such a small piece.)
Final product only needs the 2 original bolts in the appropriate holes for the bar, - like the factory setup. :)
These brackets look high quality! I am getting ready to install them. Quick question. My truck is lifted 2" in the front and 2.5" in the rear. Will I be ok just going with the lift bracket, or should I also run the drop bracket? Thanks!
I'd say mock up the axle-side bracket first, and see if your bar is levelled - proceed from there ;)
I installed the bracket this weekend. Wanted to post my results. I have OME 906 springs in the rear with 2 10mm spacer packets, approx 2.5" lift. I just used the lift bracket and left the OE mounting spot for the body end of the panhard bar. With my setup, the panhard bar is about 95% level but the rear end sits 100% center with the truck. VERY happy with this bracket! Thanks again!!
Any change in ride and handling of the truck?
youngrk
