FS: Flex-a-Lite fan 3rd Gen 4Runner Tacoma T100
Boodah
Member
For sale is my Flex-a-Lite dual puller cooling fan.
This will bolt into 1996-2001 4Runner, 1995-2001 Tacoma, and T100's with the 3.4L motor. It may fit other year Toyota models with the 3.4L motor.
Installing this fan will increase torque.
It was removed when the rubber cushion liner wore down ( see pics )
The cushion liner can be easily replaced.
Slight damage at one connector but it does not effect the function.
It is in good working condition.
Included are brand NEW fan blades.
It can be wired to run with a toggle switch for simple on and off functionality ( recommended )
An AC control can be purchased if you want the fan to turn on when the AC is switched on ( this can be purchased from Flex-a-Lite)
$60
Located in LA Cali
workingwheelswnc
