FS: JL Amp and 12" Mtx subs 325$obo- NOVA, VA, DC
santana
$325 or shoot me an offer. I need the space in the back of the 4runner! Located near Dulles airport
Thanks for looking
JL Audio A1400 Amp
MTX Thunder Ported Box with two 12" Subwoofers
I took very good care of this system and it sounds great. Deep bass and great amp that you can adjust to your liking. I also have some of the necessary cables.
JL A1400 Amp specs -
JL Audio builds their A-Series amplifiers with the high-end technology that's made their amps legendary. These hard-working amps feature an advanced thermal and low-impedance protection system that doesn't shut your amp down when the going gets tough. Instead, it rolls back peak voltage demands to protect the amp, while continuing to play your music at a safe power level.
The A1400 mono amplifier puts out up to 500 watts RMS, and JL Audio's patented Class-D amp circuitry keeps a tight rein on cone movement. JL Audio amps use "differential-balanced inputs" to isolate the signal's ground from the chassis ground, reducing noise and making this amp compatible with almost any system, including most factory radios.
JL Audio A Series A1400 Mono subwoofer amplifier 500 watts RMS x 1 at 2 ohms at Crutchfield.com
MTX Thunder 12" Sub specs -
MTX Thunder5500 T5512-04 12" 4-ohm subwoofer at Crutchfield.com
still available but i am trying to sell these items locally
i am out of town till later in the month anyway
minearcj33
