FS: NorCal (will ship) - TWO LFD aluminum crossbars 5th gen - $180
MeefZah
SOLD
Two aluminum new design (with slots, not holes on top) LFD Offroad aluminum crossbars for 5th Gen 4Rs. Includes all hardware, 5mm allen, and instructions. Very solid design. Hardly used, a few scratches from mounting. Yellow paint in images is removable / water soluble and was used to orient basket placement and as indexing marks to check for bolt movement.
Mount your hi-lift, shovel, oversize spare, and all the other shit you're never actually going to use directly to these bad boys. They also are perfectly flat (not arched like OEM) so they make a way better base for a basket, or for transporting lumber, etc.
More info:
LFD Off Road - Ruggedized Crossbar 5th Gen - Aluminum
These are $110 + shipping + wait time from LFD. Selling both SHIPPED in conUS for $180; save $40 + no shipping cost. Paypal, Venmo, or Chase Quick Pay only.
Not that I'm aware of, but I would think any Yak, Thule, etc fairing would work with some tinkering.
Okay thanks. Do they go on and off fairly quickly? Easy enough to take them off when not needed?
Yeah. You don't need to remove the end cap like you do with the factory rails. These have T bolts that basically quarter turn into the rail slots and you then tighten them with the included 5mm Allen. It's easier if you use a ratchet and long 5mm extension though. Probably 10 minutes on the first time and then 5 minutes subsequent installs.
wwarren702
