FS Shrockworks Bumper off 2016 Trail - $800, Lakeland, FL
Overland Empire
***SOLD*** FS Shrockworks Bumper off 2016 Trail - $700, Lakeland, FL
Sold!
Hey guys,
We're selling the Shrockworks Bumper off our 2016 Toyota 4Runner Trail. This bumper should fit '14 and up 4Runners, but maybe not the TRD pro. Not 100% sure about that.
The bumper is powder coated black, with no top hoops, and is in great shape except for a little blemish that happened during shipping (picture attached). It's not really even noticeable on the truck, which the other pictures can attest to.
Asking $700 and can be picked up in the Tampa/Orlando FL area, or delivered within that same general area.
Winch and fairlead not included. Includes all parts that came with the bumper: bumper, skid plate, grill insert, bracket, pieces under the headlight, washer reservoir protector, and all hardware.
Here are the specs from the website:
Custom made trim pieces that mount below the headlights. This gives a clean look WITHOUT hacking up the factory bumper. They are shown painted the body color, white, in the pics. They will come to you powder coated the same color as the bumper. If you like the look of them matched to the body, just drop them off at a body shop. They can paint right over the powder coat which makes a great base coat.
• Skid plate for the washer bottle reservoir on the passenger side. This thing hangs really low and need to be covered for both protection and aesthetics. You get both standard with the ShrockWorks 5th gen 4Runner front bumper.
• 3/16" aluminum front skid plate included standard.
• Two Recovery Points. They are a FULL 1.0" thick and are welded front and rear. They accept 3/4" clevis shackles and the width prevents them from flopping around.
• Accepts FACTORY Toyota fog lights. The ones that you probably already have.
• Optimized for off road performance with greatly improved approach angles.
• Hidden winch mount accommodates most non-integrated solenoid winches up to 9500 lbs.
• Driving light mounting holes on top of the bumper.
• Extremely stiff wraparound wings resist flexing into the body.
• Looks great with or without a winch installed. No gaping empty hole where the winch would be. A license plate will cover the winch opening if you are not running a winch keeping a clean appearance. License plate mounting holes are included.
• Designed with clearance in mind for larger tire upgrades.
• Installation is a simple bolt on.
- 3/16" steel body & skids.
- 1/4" mounting brackets
- 1.0" thick plate steel recovery points
- 2 " and 1.5" x 0.120" wall high strength tubing (optional)
- All new hardware included
- Finished in a 3 stage show quality, super durable powder coat. No thin, peeling off stuff here. (optional)
- 137 lbs
If you have any questions please don't hesitate to ask.
