FS spacer 6 Lug 6x5.5 Aluminum Wheel Spacer 1.25" Thick Hub Centric, $100 Las Vegas
Jeremy_A
4x New Toyota Tacoma FJ 4runenr 6 Lug 6x5.5 Aluminum Wheel Spacer 1.25" Thick Hub Centric
Located in Las Vegas, NV
Asking $100
Toyota*FJ Cruiser, 4Runner, Tacoma, Tundra*Aluminum Wheel Spacers, 6x5.5,*106mm ID*-*1.25" Thick, Hub Centric
DESCRIPTION:
These*6 on 5.5"*bolt pattern wheel spacers are 1.25" thick, adding 2.5" to the overall track width for greater stability and improved handling with a more aggressive stance.**They are easy to install, instructions are*included.* Made from high quality*6061-T6 aluminum.* They are designed to be hub centric to hub AND to the factory wheels to*help eliminate*the chance of vibrations.* They are great on the front of lifted applications to increase the track width when lifted 2" or*more, causing the IFS suspension geometry to change and narrow the stance slightly.
INCLUDES:
Four*(4) New 1.25" Thick*6x5.5" Aluminum Wheel Spacers with Pressed-In Grade*10.9 studs
Twelve*(12)*12-1.5mm Open-Ended Acorn Style Lug Nuts
Installation Instructions
FEATURES:
High Grade, Precision*Machined*6061-T6*Aluminum
1.25" Thick Spacers Add 2.5" Overall Track Width
Hub Centric the Hub AND Factory Wheel with 106mm Center Bore
Easy to Install, Instructions Included
FITS:
2007+ Toyota FJ Cruisers
1995+ Toyota Tacomas - 4WD & PreRunners
2003+ Toyota 4Runners
1999-2006 Toyota Tundras
IMPORTANT: Will not work with manual locking hubs.* Please inquire about fitment for your specific*vehicle if unsure prior to purchasing.
patnewton
