Fuel lines
suvwith20s
I have a 88 4 runner 4 cyl and Im in need for some fuel lines from the tank to the motor if you have any info on where i can order them please let me know Thanks:cowboy:
Certified fuel line (certified as in to meet federal law and withstand PSI of a typical vehicle) is sold, in mass, at auto zone or other car repair shop.
Similar to brake plumbing. You can purchase a tube cutter and the tool that makes the fitting at the end. It is actually pretty easy. The most annoying part is the actual mounting up. Run it along the frame and you can purchase various types of mounts.
Good luck!
You're probably better off going to a shop that builds hydro/brake lines and have them make a fuel line for you... unless you can find a good one at a junk yard but I don't know if I would trust that.
If you have the 22RE, it's a high pressure line with a banjo fitting, and you should be able to order it from a dealer.
Luceann
