Fuel Tank Hoses?
Lindenwood
Hello, Friends.
I am getting ready to replace my rig's fuel pump, and would like to replace all of what I am sure are a bunch of dry-rotted associated hoses.
Does anyone have a list of part numbers for essentially every rubber fuel line above or around the fuel tank?
Thanks a bunch!
-Lindenwood
Look at the fuel tank strap too....both our truck's straps had rusted into pieces, tanks were being held in with the 2 front bolts and the skid plate.
Fuel tank mount strap #77601-35060 for the 96 and 99....double-check for the '02
Thank you both!
As to the tank strap... been there, done that! I learned it the hard way when I undid the front skid bolts and was suddenly bench-pressing a full tank of fuel :P .
For anyone who has done this job, which of the hoses or lines in those diagrams would you say would be most prudent to pre-order?
I am assuming a lot of rust because rust turned a 6-hour lift install into a 3-day ordeal, and has added an additional $500 to my steering rack install to replace unusable rusted-out parts. So, I am just trying to prepare for what is like to be a PITA, heh.
Thanks!
Be aware, the fuel hose setup is different on the later years with the charcoal canister by the fuel tank. You should use a year specific hose layout diagram.
2001ATL
