Fuse help!
So I drove around for a while and replaced the 15 amp Dome fuse under the hood. I now have all of my electronics back and operational. With a voltage tester I was able to see that I am not getting any power to my dome lights even with a good fuse. Is there a relay between the dome lights and the fuse under the hood?
Sent from my SM-G930V using Tapatalk
Heh. I knew it was the DOME circuit. Yes, there is--it's called the Integration Relay, almost a mini-computer. See EWD here:
I bet you're right! OP, are you getting 12V atthe dome fuse?
Also, did you say your radio did not work and now it does?
Thanks for the info, however, that is pure hieroglyphics to me. I'll look it up bit could someone take a picture of the relay
Laredotx
