Future Plans
gamecockcountry
Im about to sell my tahoe and get an 03-04 4runner 4x4. This will be the 3rd toyota (had two tundras). So im pretty similar with the suspension set up. These are my plans
-3 inch toytec spacer, or 884 OME springs with top spacer
-1.5 inch rear spacer
-285/75/17 inch terra grapplers
-Diff drop
My main question is since these tires are only 11inches wide do I still need wheel spacers to clear the UCA? Such as I need them with 285/70/17s
Also can you remove the rear spoiler?
Planning on a v6 also because I don't want all-time 4wd
-Diff drop
I'm gonna comment and ask some of the "usual" questions for those who are looking at lifts. I am somewhat limited and not as good as other posters, but I'll try to help, nonetheless.
What is the lift for? functionality, aesthetics, baja/sand driving, mud crawling, trail riding, etc?
If you can answer those, then you can get a better idea which lift would be more appropriate for the particular application...
From what I've read, the diff drop is pointless to do.....someone correct me if I'm wrong.
Possibly look into new UCAs once you hit that 3" mark on the lift, it will help ensure you get the proper alignment post-lift-install.
I'd think you would need wheel spacers, to keep from rubbing the UCAs....plus who said a wider stance wouldn't hurt? :guitar3:
hope it helps...
Thanks, it will be mainly for looks occasionally for the duck and turkey season on my friends land. I just remember on the tundras I had to have the diff drop of else my cv angles were horrid
And am I correct about all time 4x4 with the v8?
I believe you are correct with all time 4WD on the V8 model, but someone correct me if I'm wrong. I only have a 2WD V8.
For what you're doing, I think you'd be fine with just a spacer then. But as many other guys on here have said and experienced, it's always best to do it right the first time rather than do it one way only to go back, rip it out, and re-do it.
You'll spend more money in the long run if you change it.
I think you'd be fine with the cv angles, but again, I could be wrong. I just remember reading that many guys never really found use for the diff drop.
First thing you need to do is change your username...
But getting back on topic: Why don't you want full time 4WD? I'd take the V8 over the V6. Is there anyway you could save up for a '06? You'd get a few more features such as projector headlights, LED tail lights, and a few other cosmic things. Not a big deal because you can add most of them later, but just something to think about.
With my price range honestly probably an 03-04. But an newer one would always be nice, and just trying to think of gas mileage so leaning towards the v6 and im not sure about how I feel about all time 4wd. Whats your opinion? And I hope you're ready for the game in death valley next year haha
The full time 4x4 isn't that bad and if you ever drive in snow you'll appreciate it. Also the fuel economy isn't horrible for a truck, I could get 18mpg if I changed my driving style.
Agree with everything snowbrdr033 has said. Sounds like your biggest issue/need for the lift is to gain clearance, not maximum flex. The spacer lift will do this just fine and save you some money. If you can afford a full suspension setup with shocks/coils, then by all means do it. Just don't feel like you have to have it based on your needs (based on what you've posted so far).
UCAs are a nice addition at 3" lift, but not required. It all depends on the route you take. They made a big difference in the way mine handled (with 3.5" of lift).
The diff drop does very little for the 4th Gen 4runners. It really doesn't help the CV angles and isn't worth it IMO. The CV angles are fine with 3" of lift, and it just doesn't seem right to lift the vehicle only to lower the diff.
Those tires are boarder line most likely. I think you can run them without the spacers, but spacers would really improve the stance. Another thing to think about, you'll need a body mount chop to clear them along with a decent amount of trimming.
If you haven't already, read the suspension sticky at the top of this page. It will give a lot of info on the various lift setups, tire sizes, etc. May also help you narrow down the type of lift, and give you an idea of available options.
When buying a 4runner, be aware the some are equipped with a hydraulic suspension called XREAS. This limits your options for a lift. You can ditch it for aftermarket shocks/coils, but it's harder to find a shop willing to work with it. If you're doing the work yourself, it's not a big deal. All Sport Editions and some Limiteds come with the XREAS. More info on this is in the suspension sticky.
That said, I love my v8 4x4. To be honest, there have been a several recent posts about head gasket issues on the v6 that really have me concerned. Considering the number of 4runners out there, very few have failed. However, there are more issues that members have posted about here than I feel should be normal.
Having had my V-8 4wd here for a short time, I am growing to love it. I thought I would get maybe a little vibration from everything turning at the same time but I don't notice a thing. We have had very little snow this winter in WI but the drive through it with the Runner feels pretty good. I had one incident where a guy decided a quick left turn was in order. I darted to the opposite lane in the snow, the ESC kicked in and I put my foot into it and it launched the truck into safety. I didn't even think about it and the truck helped me through. I know the V-6 would do the same but just the power of the V-8 made me smile and get away from any accidents that may have happened behind me.
