gas gauge not working properly
I'm having a problem with my 88 truck the gas gauge isn't wiring properly. when i idle in a parking lot or drive way my gas gauge is working fine but when I'm driving like on the high way the needle flat lines to empty but when i park it in a drive way after driving and let it idle the gauge works again any ideas on what could be the problem?
The only thing I can think of is the sending unit is bad. Other than that there isn't much that the gas gauge goes off of to my knowledge.
Good luck.
Not positive but i think you can get to the sending unit from the access panel under the left back seat. Much easier than dropping the gas tank.
The fuel pump is under the rear seat hatch, but the sender is not. If it's bad, he'll have to drop the tank.
I don't know how the sender knows if he's idling or driving though. I smell a wiring issue.
charlesz
