Gas Mileage Problem
superj80
I just purchased a 2003 4Runner SR5 V8 and I am looking into the possibility of better gas mileage. Does anyone out there know of any ECU mods or bolt ons that might help me get better gas mileage?
Yeah... Trade it for a Prius. J/K
The best you can do is be diligent with your P/M; keep you fluids, filter, plugs, etc. changed and most importantly of all? Keep your foot out of it.
Sorry I can't offer any "miracle" solution, but truth is, these engines are designed to run efficiently as they can... mostly.
Hope that helps.
Well, when you say you're looking to improve, what are your current numbers?
Best way to improve is to stay off of the skinny pedal. Jackrabbit starts and big highway speeds are MPG killers.
Put on skinnier tires, especially tires w/ a lower rolling resistance. You can also keep the speed ~55 on the highway and by doing so, pretty much wind up with 22-24 MPG.
Think of that as a savings in gasoline. 12,000 a year at $4 a gallon netting 18 mpg is $2,666. Increase that to 22 mpg (22%) and you instead pay $2,181 (or $40 a month).
Now do the math as to how much your time is worth. 12,000 at 55 is 218 hours versus 12,000 at 65 is 184 hours or 2.8 hours a month. $14/hour.
Your call, but my free time is generally worth more than $14 an hour or $40/month.
This, FTW.
Are you 2wd or 4wd? If you are 4wd, remember V8 gets you full time 4wd, too.
A Scangauge or Ultragauge can give you instant feedback on MPG which will help you modify your driving style to get better MPG. I prefer the Scangauge because it also allows you to see the transmission temperature, while the Ultra Gauge does not.
Just know that if your driving includes a lot of stop/go city driving or a lot of hills, you MPG is not going to be that good. Nothing you can do about that on a 4500lb, V-8 equipped vehicle. :shrug:
theres quite a few chip options that lean out the air to fuel ratio claiming to gain power and increase gas mileage but I'm fairly certain they've all been proven to do mostly nothing.
Clean air filter, fresh sparkplugs, removing any unnecessary cargo weight, good radial street tires. are about the best things you can do to maintain decent fuel mileage
(I didnt buy my V8 for gas mileage :beer:)
The EPA has done some extensive studies on many of the so-called gas saving devices...and they've yet to find EVEN ONE that comes close to what they say their product does.
There are a few options already mentioned..
Skinnier tires is one..but don't compromise safety. Too skinny can effect handling.
Highway tires get better gas mileage..but you sacrifice safe ability to drive in adverse weather (like snow).
How you drive is going to be the biggest factor that effects gas mileage. I'm NOT saying to do that hyper-milling crap. That type of driving can be dangerous. But just avoid jack-rabbit starts. Keep your speed down. Don't drive aggressively. Even with all that...you'll only see marginal increased in gas mileage. Maybe 1-3mpg at MOST.
You don't need to drop you speed by 10mph to gain mpg...
I dropped my average speed on the highway from 70mph to 67mph, and netted a 2mpg gain in one tank of gas in similar driving scenarios. (majority highway)
That said, obviously, dropping from 65 to 55 is about a 400rpm difference, netting you seemingly significant mpg gains. However, doing 55 in a 65 is incredibly dangerous. On average, I find that people drive 5mph-15mph OVER the speed limit, especially on divided highways. So if someone is cruising along at 80, they're gaining on you at 25mph rather than 15mph (55mph v 65mph) which is a difference of about 15fps. Our normal visual and mental cues are tuned into the normal pace of traffic, which dumbs down reaction time. We relax on the highway.
If you think a normal lane change takes about 5 seconds, thats 75 feet extra that you're giving the person coming up on you. (Or, 75 less feet they have to complete a normal lane change)
I have, a couple times, come up on someone and started a normal lane change, only to realize they're going considerably slower than the posted speed, and had an Oh ****! moment and had to either brake or swerve to avoid them.
Those situations are what cause backups and log jams in heavy traffic situations. Ever notice that there's a big backup going past the truck going uphill? Case in point.
So please, keep it at 65, and realize you own a 5000lb vehicle with a V8. You may want to hit that 22mpg sweet spot, but you'll be keeping the rest of the road, and yourself, safer.
I average and I have reset a hundred times the avg mpg but I average 22 mpg hwy and 17-18 city. I have a full size roof rack, brush guard, tail light guards and running 265-70-17 AT tires. Interstate speed here is 75 and I stay at 70-75 but trick here is cruise control. It's my best friend and saves gas big time. Just make sure to keep up on oil, fluids, filters and more. Make sure tires have right air pressure and balance. And dont forget you have a cabin air filter too.
I've been wondering the same thing, OP.
I keep hearing about V8's getting 18-22mpg, and have yet to even sniff that.
I've been charting my fuel economy religiously, and get 14-16mpg. My daily commute entails a good stretch of highway in the opposite direction of rush hour, so no stop-and-go, plus I have a long highway run 3x/week for my hobby. I dont jack rabbit start, I'm at 65mph or under on the highway.
I had a full engine service not two months ago (timing belt, water pump, plugs, *all* fluids changed and/or flushed), reset my ECU, tires are at 38psi, and I'm still getting nothing close to this magical 18-20MPG.
I'm starting to wonder if:
1) Maybe my MAF needs to be cleaned
or
2) People who claim 20MPG are getting that number off of the "Optimism Meter" on the dashboard rather than actually doing the numerical calculations at the pump...
I think its #2:
http://www.fueleconomy.gov/feg/Find.do?action=sbs&id=19241
I upsized my stock tires and didn't see any decline in fuel economy. I realize it makes sense that fuel economy should drop with bigger tires, but my own calculations show that bigger tires on my own 4Runner really didn't negatively affect fuel econony. And yes, I factored in the larger tire diameter when I calculated my fuel economy.
You know what did make a difference though? When I installed a 2/1 leveling lift, my fuel economy dropped by an average of 2 to 3 mpg. That surprised me, but honestly I'm not too concerned with fuel economy. I just drive my car when I want good gas mileage.
On my 4runner and my friends 4runner the results were oppostie of yours. We noticed no mileage difference with the lift and lost 1.5-2 mpg with 1" taller heavier BFG all terrains. Stock I could get 17.5-18 mpg now 15.5-16 mpg.
Here's an excerpt from some of my records. The biggest change are upsizing the tires. And no, I don't use the meter solely, but compare the meter against the actual amount of gas I use.
My computer crashed earlier so I haven't had a chance to update the 2012 records.
But basically, first two years I was getting ~18 mpg. Switched to larger tires and I'm down ~2 mpg.
As always, YMMV.
Code:
Date	Range	MPG	MPH	 Per Gallon 	 Cost 	 Gallons 	 MPG 	 Mileage Est. 	Mileage Adj./Notes
2-Feb-08				 $2.879 	 $10.00 	 3.474
18-Feb-08				 $3.099 	 $51.40 	 17.082 		 265 	 264.77
23-Feb-08	349.00	19.5	46	 $3.039 	 $57.80 	 19.019 	 18.350 	 614
28-Feb-08	357.00	19.6	31	 $3.339 	 $65.25 	 19.542 	 18.268 	 971
	334.00	21.2	46	 $3.319 	 $59.50 	 17.927 	 18.631 	 1,305 	1,500:  Oil & Filter
1-Mar-08	263.50	20.4	48	 $3.359 	 $46.25 	 13.769 	 19.137 	 1,568
	410.00	20.1	38	 $3.479 	 $80.00 	 23.000 	 17.826 	 1,978
9-Mar-08	336.90	18.5	33	 $3.199 	 $59.50 	 18.598 	 18.115 	 2,315
14-Mar-08	358.70	20.0	32	 $3.479 	 $66.50 	 19.115 	 18.765 	 2,674
16-Mar-08	259.30	19.3	42	 $3.239 	 $45.75 	 14.125 	 18.358 	 2,933
22-Mar-08	396.80	20.4	36	 $3.499 	 $72.95 	 20.849 	 19.032 	 3,330
	279.30	19.8	41	 $3.259 	 $48.00 	 14.728 	 18.964 	 3,609
	372.50	19.9	32	 $3.389 	 $69.47 	 20.500 	 18.171 	 3,982
	252.00	19.4	45	 $3.319 	 $45.50 	 13.708 	 18.383 	 4,234
5-Apr-08	391.50	19.4	33	 $3.689 	 $76.85 	 20.832 	 18.793 	 4,625
	341.40	18.7	37					 4,967 	5,000:  Oil & Filter
11-Apr-08	377.20	19.5	36	 $3.679 	 $76.00 	 20.658 	 18.259 	 5,344
14-Apr-08	392.80	19.4	50	 $3.689 	 $77.50 	 21.008 	 18.698 	 5,737
19-Apr-08	356.20	18.5	34	 $3.779 	 $80.00 	 21.169 	 16.826 	 6,093
	395.80	19.0	36	 $3.749 	 $81.36 	 21.702 	 18.238 	 6,489
28-Apr-08	376.40	19.0	39	 $3.839 	 $79.50 	 20.708 	 18.177 	 6,865
3-May-08	375.60	19.8	37	 $3.769 	 $78.20 	 20.748 	 18.103 	 7,241 	7,500:  Oil & Filter
9-May-08	402.50	18.9	35	 $3.839 	 $88.10 	 22.949 	 17.539 	 7,643
12-May-08	349.40	19.2	39	 $3.869 	 $71.85 	 18.571 	 18.814 	 7,993
16-May-08	262.20	17.9	30	 $3.859 	 $60.00 	 15.547 	 16.865 	 8,255
19-May-08	354.20	18.2	39	 $3.889 	 $80.00 	 20.570 	 17.219 	 8,609
24-May-08	249.60	17.5	29	 $4.019 	 $62.00 	 15.426 	 16.180 	 8,859
24-May-08	271.30	18.9	51	 $3.819 	 $57.00 	 14.925 	 18.177 	 9,130
30-May-08	372.70	19.8	37	 $4.150 	 $81.70 	 19.644 	 18.973 	 9,503
2-Jun-08	257.90	18.6	46	 $4.129 	 $60.50 	 14.653 	 17.600 	 9,760 	10,000:  Oil & Filter
7-Jun-08	340.90	17.9	29	 $4.339 	 $88.80 	 20.465 	 16.658 	 10,101
9-Jun-08	328.50	18.9	35	 $4.269 	 $77.00 	 18.036 	 18.214 	 10,430
13-Jun-08	260.20	16.9	34	 $4.439 	 $73.75 	 16.613 	 15.662 	 10,690
17-Jun-08	365.50	18.4	41	 $4.479 	 $95.00 	 21.210 	 17.232 	 11,056
21-Jun-08	302.10	17.2	34	 $4.459 	 $81.75 	 18.334 	 16.478 	 11,358
21-Jun-08	238.50	17.5	54	 $4.099 	 $58.00 	 14.149 	 16.856 	 11,596
28-Jun-08	380.40	20.4	39	 $4.394 	 $88.50 	 20.128 	 18.899 	 11,977
1-Jul-08	324.40	19.9	45	 $4.459 	 $76.75 	 17.213 	 18.846 	 12,301
4-Jul-08	202.90	18.1	42	 $4.389 				 12,504
7-Jul-08	358.30	19.9	44	 $4.379 	 $83.30 	 19.023 	 18.835 	 12,862
12-Jul-08	290.80	17.5	28	 $4.359 	 $75.85 	 17.400 	 16.713 	 13,153
15-Jul-08	320.00	20.2	46	 $4.329 	 $73.00 	 16.862 	 18.978 	 13,473
25-Jul-08	364.50	17.9	32	 $4.229 	 $95.50 	 22.582 	 16.141 	 13,837
29-Jul-08	364.40	18.6	33	 $4.129 	 $84.00 	 20.343 	 17.913 	 14,202
2-Aug-08	355.80	18.2	37	 $4.019 	 $84.85 	 21.111 	 16.854 	 14,558
7-Aug-08	386.20	19.0	42	 $4.059 	 $86.50 	 21.310 	 18.123 	 14,944 	15,000:  Engine Air Filter
12-Aug-08	394.40	19.1	40	 $3.849 	 $83.25 	 21.628 	 18.236 	 15,338
15-Aug-08	216.10	17.3	38	 $3.939 	 $53.75 	 13.645 	 15.837 	 15,554
23-Aug-08	270.90	16.8	32	 $3.849 	 $67.31 	 17.500 	 15.480 	 15,825
26-Aug-08	316.90	19.3	35	 $3.719 	 $65.00 	 17.477 	 18.132 	 16,142
28-Aug-08	199.50	17.2	32	 $3.859 	 $46.00 	 11.921 	 16.735 	 16,342
30-Aug-08	221.90	16.7	34	 $3.679 	 $51.00 	 13.862 	 16.008 	 16,564
6-Sep-08	370.70	18.2	37	 $3.829 	 $83.00 	 21.677 	 17.101 	 16,934
9-Sep-08	304.50	19.2	53	 $3.659 	 $61.50 	 16.808 	 18.116 	 17,239
23-Sep-08	356.80	18.5	43	 $3.569 	 $72.50 	 20.314 	 17.564 	 17,596
27-Sep-08	244.70	17.7	31	 $3.659 	 $54.00 	 14.759 	 16.580 	 17,840
30-Sep-08	301.70	19.9	53	 $3.489 	 $55.25 	 15.835 	 19.053 	 18,142
4-Oct-08	217.50	17.9	34	 $3.529 	 $47.00 	 13.319 	 16.330 	 18,359 	18,500:  Oil & Filter
7-Oct-08	400.30	20.8	45	 $3.570 	 $74.00 	 20.676 	 19.361 	 18,760
11-Oct-08	175.10	18.1	37	 $3.399 	 $36.00 	 10.592 	 16.531 	 18,935
14-Oct-08	316.10	18.4	52	 $3.339 	 $59.00 	 17.699 	 17.860 	 19,251
18-Oct-08	288.50	18.8	38	 $3.299 	 $54.75 	 16.596 	 17.384 	 19,539
22-Oct-08	345.10	18.1	45	 $3.489 	 $70.35 	 20.106 	 17.164 	 19,885 	20,000:  Cabin Filter
25-Oct-08	396.50	20.5	44	 $2.679 	 $54.30 	 20.267 	 19.564 	 20,281
30-Oct-08	392.20	20.0	44	 $2.429 	 $51.50 	 21.201 	 18.499 	 20,673
31-Oct-08	343.50	20.2	41	 $2.499 	 $41.65 	 17.655 	 19.456 	 21,017
6-Nov-08	348.10	19.7	37	 $2.359 	 $45.00 	 19.076 	 18.248 	 21,365
8-Nov-08	308.90	18.5	37	 $2.359 	 $41.65 	 17.655 	 17.496 	 21,674
14-Nov-08	375.90	20.2	38	 $2.239 	 $44.50 	 19.874 	 18.914 	 22,050
16-Nov-08	288.60	18.1	40	 $2.189 	 $37.50 	 17.131 	 16.847 	 22,338
21-Nov-08	336.80	19.8	38	 $1.989 	 $36.75 	 18.475 	 18.230 	 22,675
24-Nov-08	338.00	18.4	39	 $1.799 	 $34.60 	 19.235 	 17.572 	 23,013
28-Nov-08	327.30	18.4	30	 $1.829 	 $35.56 	 19.432 	 16.843 	 23,340
1-Dec-08	351.30	19.8	47	 $1.719 	 $32.50 	 18.909 	 18.578 	 23,692
9-Dec-08	350.40	18.4	29	 $1.679 	 $35.50 	 21.145 	 16.571 	 24,042
12-Dec-08	345.10	18.7	31	 $1.633 	 $33.00 	 20.206 	 17.079 	 24,387
14-Dec-08	266.00	18.1	48	 $1.679 	 $27.50 	 16.378 	 16.241 	 24,653
17-Dec-09				 $1.859 	 $20.01 	 10.762 		 24,820 	 166.81
18-Dec-08	497.80	20.0	40	 $1.699 	 $27.00 	 15.889 	 31.330 	 25,318 	25,500:  Oil & Filter
20-Dec-08	329.60	18.4	41	 $1.579 	 $30.00 	 18.998 	 17.349 	 25,647
23-Dec-08	331.40	19.2	37	 $1.579 	 $29.50 	 18.685 	 17.736 	 25,979
23-Dec-08	164.50	19.1	41	 $1.739 	 $17.00 	 9.774 	 16.830 	 26,143
27-Dec-08	378.30	19.5	43	 $1.799 	 $40.92 	 23.262 	 16.263 	 26,522
27-Dec-08				 $1.799 	 $37.25 	 20.708 		 26,843 	 320.97
29-Dec-08	253.90	17.7	39	 $1.759 	 $27.00 	 15.349 	 16.542 	 27,096
30-Dec-08	277.70	20.0	42	 $1.799 	 $27.00 	 15.007 	 18.505 	 27,374
2008 Total	26621.60	18.9	39.0	 $3.281 	 $4,951.84 	1508.8	17.9	 27,374
2-Jan-09	229.70	18.6	39	 $1.659 	 $22.00 	 13.264 	 17.318 	 27,604
5-Jan-09	367.90	18.8	36	 $1.679 	 $34.75 	 20.948 	 17.563 	 27,972
8-Jan-09	368.60	18.3	37	 $1.839 	 $40.00 	 21.749 	 16.948 	 28,340
12-Jan-09	409.10	19.9	35	 $1.889 	 $37.75 	 19.985 	 20.470 	 28,749 	+2 Gallons
15-Jan-09	296.50	19.4	35	 $1.979 	 $33.00 	 16.673 	 17.783 	 29,046
17-Jan-09	315.70	18.7	36	 $1.899 	 $34.50 	 18.165 	 17.380 	 29,362 	29,360:  Cabin Filter, Air Filter, Oil Pan Washer, Oil & Filter (full synthetic)
22-Jan-09	394.70	19.8	36	 $1.959 	 $41.75 	 21.313 	 18.519 	 29,756 	31731: Propeller/Drive shaft (6 Zerks) Mobil 1 Synthetic
24-Jan-09	315.70	18.9	40	 $1.959 	 $35.00 	 17.864 	 17.672 	 30,072 	31779: Oil & Filter Mobil 1 0W-30 Synthetic
26-Jan-09	283.20	19.1	45	 $1.959 	 $31.00 	 15.823 	 17.898 	 30,355
28-Jan-09	386.00	19.7	40	 $1.979 	 $41.60 	 21.023 	 18.361 	 30,741
2-Feb-09	384.30	19.9	34	 $1.979 	 $41.50 	 20.969 	 18.327 	 31,126
6-Feb-09	293.10	19.8	32	 $2.099 	 $34.00 	 16.196 	 18.097 	 31,419
7-Feb-09	318.40	19.0	47	 $2.059 	 $36.50 	 17.729 	 17.959 	 31,737
12-Feb-09	356.60	19.1	39	 $2.159 	 $44.00 	 20.381 	 17.497 	 32,094
13-Feb-09	155.20	18.1	31	 $2.199 	 $19.50 	 8.868 	 17.501 	 32,249
15-Feb-09	396.20	18.9	35	 $2.279 	 $48.50 	 23.189 	 17.086 	 32,645
16-Feb-09	155.50	16.1	52	 $2.499 	 $26.75 	 10.704 	 14.527 	 32,801
17-Feb-09	378.80	19.2	36	 $2.119 	 $44.25 	 20.881 	 18.141 	 33,179
21-Feb-09	378.00	18.0	38	 $2.159 	 $49.00 	 22.696 	 16.655 	 33,557
27-Feb-09	398.80	19.2	37	 $2.099 	 $47.00 	 22.393 	 17.809 	 33,956
1-Mar-09	316.20	17.5	38	 $2.139 	 $41.00 	 19.168 	 16.496 	 34,272
6-Mar-09	323.50	19.5	38	 $2.039 	 $36.40 	 17.854 	 18.119 	 34,596
8-Mar-09	250.90	19.0	38	 $2.139 	 $30.00 	 14.023 	 17.892 	 34,847
11-Mar-09	357.40	18.7	45	 $1.989 	 $40.50 	 20.360 	 17.554 	 35,204
20-Mar-09	328.20	23.0	17.5	 $1.999 	 $40.50 	 20.262 	 16.198 	 35,532
24-Mar-09	362.90	18.5	41	 $2.029 	 $42.00 	 20.700 	 17.531 	 35,895
27-Mar-09	235.00	18.3	38	 $2.119 	 $29.00 	 13.684 	 17.173 	 36,130
28-Mar-09	271.00	18.0	45	 $2.059 	 $32.40 	 15.738 	 17.219 	 36,401
29-Mar-09	386.10	18.9	58	 $2.159 	 $46.50 	 21.538 	 17.926 	 36,787 	36848:  Oil change (0-30W Synthetic), Rotate Tires (5 way), Lube Yoke Shaft (6 spots w/ Mobil 1)
3-Apr-09	372.80	18.3	43	 $2.149 	 $46.00 	 21.404 	 17.417 	 37,160
4-Apr-09	263.40	18.1	43	 $2.059 	 $32.00 	 15.541 	 16.949 	 37,424
10-Apr-09	342.80	18.6	38	 $2.210 	 $42.50 	 19.151 	 17.900 	 37,766
13-Apr-09	308.30	18.3	41	 $2.099 	 $37.00 	 17.629 	 17.488 	 38,075
17-Apr-09	353.00	18.6	39	 $2.199 	 $44.00 	 20.007 	 17.644 	 38,428
20-Apr-09	339.80	18.2	48	 $2.209 	 $43.00 	 19.465 	 17.457 	 38,767
24-Apr-09	325.00	17.4	31	 $2.179 	 $43.75 	 20.079 	 16.186 	 39,092
27-Apr-09	322.90	19.0	49	 $2.200 	 $39.00 	 17.655 	 18.289 	 39,415
1-May-09	318.70	17.4	29	 $2.219 	 $44.00 	 19.828 	 16.073 	 39,734
8-May-09	223.00	17.6	23	 $2.299 	 $31.00 	 13.482 	 16.541 	 39,957
11-May-09	305.00	18.0	38	 $2.199 	 $39.00 	 17.736 	 17.197 	 40,262
15-May-09	373.50	18.6	23	 $2.299 	 $31.00 	 13.482 	 27.704 	 40,636
18-May-09	426.70	18.8	43	 $2.399 	 $51.25 	 21.863 	 19.517 	 41,062
24-May-09	331.20	16.6	26	 $2.539 	 $54.50 	 21.464 	 15.430 	 41,393
1-Jun-09	385.60	18.4	33	 $2.319 	 $47.25 	 18.005 	 21.416 	 41,779
5-Jun-09	396.60	19.6	38	 $2.799 				 42,176
8-Jun-09	568.10	18.7	40	 $2.479 				 42,744
12-Jun-09	389.50	19.8	35	 $2.899 	 $28.50 	 21.486 	 18.128 	 43,133 	Poured in 12 gallons from previous
13-Jun-09	258.80	18.6	37	 $2.579 	 $79.00 	 14.133 	 18.312 	 43,392 	Saved 17 gallons for next
22-Jun-09	672.40	19.0	37	 $2.679 	 $102.75 	 38.355 	 17.531 	 44,064 	Saved 16.5 gallons for next
25-Jun-09	884.00	19.4	42					 44,948
30-Jun-09				 $2.639 	 $100.02 	 37.900
3-Jul-09	587.40	18.1	38	 $2.619 	 $34.52 	 34.517 		 45,536
11-Jul-09				 $2.679 	 $41.00 	 15.305 			46,411 air filter changed [Yosemite weekend]
12-Jul-09				 $2.579 	 $98.00 	 37.998 		 46,520
20-Jul-09	601.80	18.2	31	 $2.699 	 $57.75 	 21.398 	 28.124 	 47,122
25-Jul-09	479.20	18.6	38	 $2.599 	 $64.34 	 24.755 	 19.358 	 47,601
26-Jul-09	471.20	19.9	42	 $2.590 	 $24.57 	 63.840 	 7.381 	 48,072
28-Jul-09	337.10	17.9	27	 $2.699 	 $55.00 	 20.379 	 16.542 	 48,409
1-Aug-09	251.80	18.2	33	 $2.699 	 $40.00 	 14.822 	 16.988 	 48,661
3-Aug-09	265.70	16.6	24	 $2.759 	 $47.00 	 17.036 	 15.596 	 48,927
6-Aug-09	193.40	17.2	28	 $2.859 	 $34.25 	 11.980 	 16.144 	 49,120
7-Aug-09	254.10	18.0	47	 $2.699 	 $83.66 	 30.998 	 8.197 	 49,374
13-Aug-09	390.40	19.4	41	 $2.869 	 $62.50 	 21.786 	 17.920 	 49,765
17-Aug-09	388.60	18.6	40	 $2.859 	 $61.85 	 21.632 	 17.964 	 50,153
21-Aug-09	328.60	18.2	30	 $2.899 	 $56.40 	 19.456 	 16.889 	 50,482
22-Aug-09	230.40	18.1	41	 $2.719 	 $36.00 	 13.241 	 17.400 	 50,712
27-Aug-09	370.70	19.4	34	 $2.899 	 $59.50 	 20.525 	 18.061 	 51,083
28-Aug-09	363.80	19.5	46	 $2.959 	 $58.55 	 19.790 	 18.383 	 51,447
29-Aug-09	241.10	18.5	40	 $2.899 	 $39.00 	 13.453 	 17.922 	 51,688
31-Aug-09	306.30	18.9	27	 $2.739 	 $56.00 	 20.444 	 14.982 	 51,994
4-Sep-09	344.60	18.4	31	 $2.959 	 $60.00 	 20.277 	 16.995 	 52,339 	 52594 Oil & Filter Change, rotate tires
10-Sep-09	623.00	18.7	34	 $2.990 	 $63.75 	 21.257 	 29.308 	 52,339
13-Sep-09	411.20	17.5	30	 $2.759 	 $55.00 	 19.934 	 20.628 	 52,339
13-Sep-09				 $2.759 	 $52.19 	 18.917 		 53,420
18-Sep-09	378.60	17.5	33	 $2.899 	 $62.00 	 21.385 	 17.704 	 53,799
21-Sep-09	399.20	18.5	36	 $2.919 	 $66.00 	 22.609 	 17.657 	 54,198
26-Sep-09	362.40	16.8	23	 $2.799 	 $65.00 	 23.221 	 15.607 	 54,560
28-Sep-09	399.30	18.4	35	 $2.759 	 $63.00 	 22.834 	 17.487 	 54,960
2-Oct-09	385.50	18.7	33	 $2.759 	 $55.50 	 20.117 	 19.163 	 55,345
9-Oct-09	650.70	18.4	36	 $2.799 	 $59.50 	 21.259 	 30.608 	 55,996
12-Oct-09	400.20	18.3	30	 $2.639 	 $100.00 	 37.894 	 10.561 	 56,396
17-Oct-09	390.50	18.8	33	 $2.790 	 $62.00 	 22.149 	 17.631 	 56,786 	57,069:  Cabin Air Filter
20-Oct-09	323.70	18.0	36	 $2.599 	 $49.50 	 19.046 	 16.996 	 57,110
23-Oct-09	316.60	20.0	37	 $2.799 	 $46.50 	 16.613 	 19.057 	 57,427
25-Oct-09	304.80	18.7	37	 $2.599 	 $54.50 	 20.969 	 14.536 	 57,732 	57,644:  Oil & Filter change, rotate tires
31-Oct-09	357.90	20.0	37	 $2.809 	 $54.00 	 19.224 	 18.617 	 58,089
1-Nov-09	287.20	18.4	39	 $2.619 	 $43.00 	 16.418 	 17.493 	 58,377
6-Nov-09	375.60	20.4	33	 $2.809 	 $54.50 	 19.724 	 19.043 	 58,752
10-Nov-09	437.10	19.9	41	 $2.789 	 $52.00 	 18.839 	 23.202 	 59,189
20-Nov-09	308.00	18.1	26	 $2.769 	 $50.50 	 18.237 	 16.889 	 59,497
22-Nov-09	292.40	18.7	37	 $2.659 	 $56.17 	 21.126 	 13.841 	 59,790
25-Nov-09	316.50	18.8	39	 $2.769 	 $37.00 	 13.361 	 23.688 	 60,106
29-Nov-09	466.20	19.7	42	 $2.639 	 $85.00 	 32.208 	 14.475 	 60,572 	60,977:  Rotate tires & fix flat
11-Dec-09	503.10	18.9	32	 $2.749 	 $40.00 	 14.550 	 34.577 	 61,076 	61,350:  New tires
13-Dec-09	267.30	16.7	37	 $2.659 	 $82.00 	 30.838 	 8.668 	 61,343 	61,486:  Alignment
19-Dec-09	639.00	17.6	33	 $2.679 	 $100.00 	 37.328 	 17.119 	 61,982 	61,327:  Change air filter
23-Dec-09	340.80	17.8	35	 $2.739 	 $55.50 	 20.264 	 16.818 	 62,323 	62,872:  Oil & Filter change, lube yokes, rear sway bar bushings
26-Dec-09	311.80	17.1	32		 $53.00 			 62,634
31-Dec-10	527.00	18.6	34	 $2.769 	 $50.00 	 18.057 	 29.185 	 63,161
2009 Total	 34,756.10 	18.61	36.45	 $2.46 	 $4,753.16 	1974.82	18.02	 35,558
3-Jan-10	276.10	17.1	39	 $2.699 	 $83.53 	 30.949 	 8.921 	 63,438
7-Jan-10	333.50	18.7	32	 $2.879 	 $55.25 	 19.192 	 17.377 	 63,771
15-Jan-10	228.30	15.9	22	 $2.839 	 $44.50 	 15.674 	 14.566 	 63,999
21-Jan-10	539.50	17.1	37	 $2.759 	 $20.15 	 55.600 	 9.703 	 64,539
24-Jan-10	337.00	15.8	31	 $2.679 	 $96.30 	 35.946 	 9.375 	 64,876
29-Jan-10	356.50	18.9	34	 $2.639 	 $53.00 	 20.003 	 17.822 	 65,232
1-Feb-10	318.30	16.4	37	 $2.799 	 $57.00 	 20.363 	 15.631 	 65,551
4-Feb-10	255.30	18.1	30	 $2.799 	 $43.00 	 15.362 	 16.619 	 65,806
8-Feb-10	350.60	16.0	33	 $2.639 	 $61.35 	 23.247 	 15.082 	 66,157
12-Feb-10	349.20	18.0	37	 $2.739 	 $56.50 	 20.628 	 16.928 	 66,506
14-Feb-10	351.80	18.1	38	 $2.759 	 $56.00 	 20.660 	 17.028 	 66,858
18-Feb-10	326.90	18.3	35	 $2.739 	 $51.50 	 18.801 	 17.387 	 67,184
25-Feb-10	467.20	17.0	37	 $2.779 	 $56.50 	 20.330 	 22.981 	 67,652 	67,733:  Oil & Filter, Lube Drive Shaft
1-Mar-10	406.10	16.3	29	 $2.759 	 $56.50 	 20.607 	 19.707 	 68,058
5-Mar-10	284.40	16.9	31	 $2.919 	 $52.30 	 17.916 	 15.874 	 68,342
6-Mar-10	246.10	17.0		 $2.739 	 $81.30 	 29.683 	 8.291 	 68,588
12-Mar-10	349.30	17.6	33	 $2.979 	 $20.50 	 6.883 	 50.748 	 68,938
15-Mar-10	367.50	17.2	35	 $2.819 	 $59.00 	 20.928 	 17.560 	 69,305
18-Mar-10	217.00	17.6	30	 $2.959 	 $40.00 	 13.518 	 16.053 	 69,522 	Windshield Replace $135
22-Mar-10	333.90	16.4	30	 $2.859 	 $100.00 	 34.978 	 9.546 	 69,856
23-Mar-10	365.10	18.7	43	 $2.859 	 $58.06 	 20.309 	 17.977 	 70,221
26-Mar-10	353.80	17.9	31	 $2.869 	 $58.00 	 20.217 	 17.500 	 70,575
29-Mar-10	353.80	17.2	33	 $2.869 	 $61.25 	 21.350 	 16.571 	 70,929
2-Apr-10	285.80	16.3	31	 $2.879 	 $53.50 	 20.217 	 14.137 	 71,214 	71,410:  Cabin Air Filter, Tire Rotation
6-Apr-10	331.80	16.3	39	 $2.869 	 $62.00 	 21.612 	 15.353 	 71,546
9-Apr-10	309.80	17.6	33	 $2.909 	 $53.00 	 18.221 	 17.002 	 71,856
13-Apr-10	316.20	16.9	35	 $2.909 	 $57.30 	 19.699 	 16.052 	 72,172
15-Apr-10	321.30	17.9	32	 $2.929 	 $55.25 	 18.862 	 17.034 	 72,494
21-Apr-10	472.40	17.5	37	 $2.979 	 $58.00 	 19.470 	 24.263 	 72,966
26-Apr-10	434.90	16.7	36	 $2.959 	 $65.00 	 21.966 	 19.799 	 73,401
28-Apr-10	361.70	17.3	42	 $2.959 	 $64.50 	 21.799 	 16.593 	 73,763
30-Apr-10	164.90	16.7	28	 $2.919 	 $30.50 	 10.448 	 15.783 	 73,927
3-May-10	354.20	17.3	34	 $2.929 	 $62.50 	 21.338 	 16.599 	 74,282
6-May-10	272.30	16.4	22	 $3.049 	 $54.50 	 17.875 	 15.234 	 74,554
8-May-10	329.90	18.1	35	 $2.839 	 $106.75 	 37.602 	 8.773 	 74,884 	74,902:  Oil & Filter, Rotate Tires, Air Filter
12-May-10	373.30	17.8	34	 $2.999 	 $66.00 	 22.007 	 2.999 	 75,257
16-May-10	333.40	16.3	31	 $2.839 	 $58.30 	 20.535 	 16.236 	 75,591
20-May-10	370.70	18.7	32	 $2.959 	 $63.00 	 21.290 	 17.412 	 75,961
23-May-10	369.60	17.2	32	 $2.839 	 $57.75 	 20.340 	 18.171 	 76,331
27-May-10	337.00	17.7	30	 $2.899 	 $58.00 	 20.007 	 16.844 	 76,668
30-May-10	294.80	16.8		 $2.799 	 $51.30 	 18.327 	 16.086 	 76,963
3-Jun-10	341.50	17.5	37	 $2.899 	 $59.40 	 20.489 	 16.667 	 77,304
4-Jun-10	285.60	17.1	43	 $2.799 	 $49.00 	 17.506 	 16.314 	 77,590
10-Jun-10	384.50	17.0	38	 $2.959 	 $56.40 	 19.063 	 20.170 	 77,974
11-Jun-10	342.30	16.5	49	 $2.799 	 $60.00 	 21.435 	 15.969 	 78,317
12-Jun-10	164.90	15.3	35	 $2.879 	 $31.25 	 11.087 	 14.873 	 78,481
16-Jun-10	124.70	16.9	33	 $2.959 	 $60.00 	 20.276 	 6.150 	 78,606
17-Jun-10	295.80	17.8	41	 $2.839 	 $49.60 	 17.471 	 16.931 	 78,902
18-Jun-10	199.70	17.4	41	 $2.859 	 $34.70 	 12.136 	 16.455 	 79,102
18-Jun-10	163.40	16.9	60	 $2.899 	 $28.65 	 9.881 	 16.537 	 79,265
18-Jun-10	248.90	13.9	60	 $2.799 	 $50.50 	 18.042 	 13.796 	 79,514
19-Jun-10	198.00	16.0	60	 $2.650 	 $35.40 	 13.116 	 15.096 	 79,712
19-Jun-10	298.00	15.3	65	 $2.999 	 $59.40 	 19.806 	 15.046 	 80,010
19-Jun-10	287.40	15.0	65	 $2.699 	 $53.40 	 19.785 	 14.526 	 80,297
20-Jun-10	267.70	14.4	62	 $2.759 	 $52.00 	 18.847 	 14.204 	 80,565
20-Jun-10	182.80	15.3	62	 $2.659 	 $33.65 	 12.656 	 14.444 	 80,748
20-Jun-10	252.90	15.5	62	 $2.719 	 $46.50 	 17.103 	 14.787 	 81,001
21-Jun-10	203.50	15.1	63	 $2.849 	 $40.00 	 14.040 	 14.494 	 81,204
21-Jun-10	298.20	16.4	57	 $2.539 	 $49.50 	 19.495 	 15.296 	 81,502
23-Jun-10	322.70	16.3	39	 $2.739 	 $56.65 	 20.683 	 15.602 	 81,825
24-Jun-10	342.30	17.7	55	 $2.699 	 $54.50 	 20.193 	 16.951 	 82,167
24-Jun-10	312.40	17.6	60	 $2.859 	 $53.85 	 18.836 	 16.585 	 82,480
24-Jun-10	240.00	19.2	58	 $2.499 	 $33.40 	 13.365 	 17.957 	 82,720
24-Jun-10	366.10	18.6	59	 $2.679 	 $60.75 	 22.676 	 16.145 	 83,086
25-Jun-10	351.00	16.8	63	 $2.479 	 $54.50 	 21.984 	 15.966 	 83,437
25-Jun-10	347.70	16.6	39	 $2.899 	 $63.25 	 21.817 	 15.937 	 83,785
26-Jun-10	355.60	18.7	46	 $2.869 	 $56.60 	 19.727 	 18.026 	 84,140
26-Jun-10	314.80	19.3	49	 $2.779 	 $46.50 	 16.731 	 18.815 	 84,455
29-Jun-10	303.00	18.0	36	 $3.039 	 $54.45 	 17.918 	 16.910 	 84,758
1-Jul-10	173.30	17.3	24	 $2.999 	 $31.50 	 10.504 	 16.498 	 84,931 	84,893:  Oil & Filter, Lube Yoke Shaft, Rotate Tires
5-Jul-10	344.20	15.4	27	 $2.799 	 $58.00 	 20.721 	 16.611 	 85,276
8-Jul-10	297.20	19.1	37	 $3.049 	 $50.15 	 16.449 	 18.068 	 85,573
9-Jul-10	266.40	16.6	39	 $2.759 	 $75.00 	 27.185 	 9.800 	 85,839 	86,225:  Cabin Air Filter
17-Jul-10	233.20	20.7	49	 $2.91 	$40.00	 13.750 	 16.959 	 86,652
19-Jul-10	336.00	18.5	49	 $2.84 	$105.25	 37.071 	 9.064 	 86,988
22-Jul-10	301.60	19.5	37	 $3.00 	$49.65	 16.554 	 18.219 	 88,124
26-Jul-10	375.00	19.1	39	 $2.96 	$56.50	 19.095 	 19.639 	 88,499
30-Jul-10	216.70	17.7	34	 $3.02 	$40.00	 13.248 	 16.357 	 88,715
31-Jul-10	274.20	18.9	40	 $2.86 	$44.00	 15.391 	 17.816 	 88,990
05-Aug-10	287.10	20.3	38	 $3.04 	$46.50	 15.300 	 18.765 	 89,277
09-Aug-10	332.40	16.7	32	 $2.88 	$58.00	 20.147 	 16.499 	 89,598 	89622 oil,filter,rotate,lube.  4633 last oil
13-Aug-10	334.60	19.2	39	 $3.04 	$56.75	 18.675 	 17.917 	 89,933
17-Aug-10	312.80	19.4	44	 $2.94 	$50.00	 17.014 	 18.385 	 90,246
20-Aug-10	333.00	18.2	37	 $2.96 	$57.75	 19.517 	 17.062 	 90,579
21-Aug-10	130.20	16.1	31	 $2.88 	$24.00	 8.335 	 15.621 	 90,709
26-Aug-10	322.30	18.8	34	 $3.00 	$54.50	 18.174 	 17.734 	 91,031
04-Sep-10	306.10	15.8	19	 $2.98 	$44.65	 14.989 	 20.422 	 91,337
05-Sep-10	283.90	16.1	31	 $2.80 	$51.50	 18.400 	 15.429 	 91,621
10-Sep-10	360.40	18.6	34	 $2.92 	$59.85	 20.583 	 17.510 	 91,982
11-Sep-10	161.20	19.6	44	 $2.86 	$25.15	 8.796 	 18.327 	 92,143
15-Sep-10	365.80	17.9	37	 $2.90 	$62.75	 21.647 	 16.898 	 92,509
18-Sep-10	141.20	16.7	22	 $2.90 	$27.00	 9.312 	 15.163 	 92,650
24-Sep-10	586.00	18.4	35	 $2.90 	$61.40	 21.179 	 27.669 	 93,236
27-Sep-10	312.8	18.9	38	 $2.77 	$47.00	 16.974 	 18.428 	 93,549
30-Sep-11				 $3.14 	$53.60	 17.074
02-Oct-10	219.6	18.8	35	 $2.90 	$37.50	 12.935 	 16.977 	 93,768
04-Oct-10	283	17.8	35	 $2.68 	$82.70	 30.870 	 9.167 	 94,046
08-Oct-10	338.1	18.6	34	 $2.92 	$56.00	 19.184 	 17.624 	 94,384
12-Oct-10	415.1	18.7	40	 $2.93 	$55.50	 18.950 	 21.905 	 94,799 	94,698 Oil, Filter, Lube and rotate tires
15-Oct-10	176.8	17.7	29	 $3.00 	$32.00	 10.669 	 16.571 	 94,976
17-Oct-10	273.4	17.3	32	 $2.74 	$57.80	 21.101 	 12.957 	 95,249
22-Oct-10	328.6	18.4	33	 $3.06 	$58.50	 19.125 	 17.182 	 95,578
27-Oct-10	602.5	18.1	33	 $3.03 	$64.50	 21.294 	 28.294 	 96,181
30-Oct-10	157.4	16.1	20	 $3.08 	$29.00	 9.420 	 16.709 	 96,338
31-Oct-10	249.9	18	46	 $2.74 	$80.30	 29.318 	 8.524 	 96,588
03-Nov-10	291.2	19.4	36	 $3.06 	$47.40	 15.495 	 18.793 	 96,879
07-Oct-10	350.7	17.1	33	 $2.77 	$60.25	 21.757 	 16.119 	 97,230
11-Oct-10	325.4	18.5	33	 $3.10 	$57.85	 18.668 	 17.431 	 97,555
19-Nov-10	256.5	16.4	21	 $3.10 	$52.35	 16.891 	 15.186 	 97,812
21-Nov-10	355.8	16.3	33	 $2.84 	$68.75	 24.215 	 14.693 	 98,168
22-Nov-10	182.3	19	34	 $3.00 	$30.00	 10.004 	 18.223 	 98,350
24-Nov-10	372.2	17.2	34	 $2.96 	$55.00	 18.587 	 20.024 	 98,722
27-Nov-10	296.9	15.9	37	 $2.84 	$69.50	 24.481 	 12.128 	 99,018
01-Dec-10	331.4	17.2	32	 $3.04 	$62.00	 20.402 	 16.244 	 99,351
04-Dec-10	322.7	16.7	40	 $2.86 	$58.50	 20.463 	 15.770 	 99,674 	99,701 oil, filter, rotate tires
10-Dec-10	332.5	18.3	36	 $3.16 	$62.00	 19.626 	 16.942 	 100,006 	100,250 plugs
16-Dec-10	595.5	18	37	 $3.20 	$69.50	 21.727 	 27.408 	 100,602
18-Dec-10	293.8	16.3	32	 $2.90 	$94.00	 32.426 	 9.061 	 100,895
23-Dec-10	350.2	17.6	33	 $3.20 	$68.00	 21.257 	 16.475 	 101,246 	101,000 brakes
28-Dec-10	578.0	16.8	33	 $3.20 	$61.51	 19.227 	 30.062 	 101,824
31-Dec-10	175.4	17.7	32	 $3.20 	$34.00	 10.830 	 16.196 	 101,999
2010 Total	 37,439.10 	17.4	38	 $2.880 	 $6,617.30 	2355.93	15.9	 38,562
Per Month	1039.98				 $183.81 	 65.44 		1071.15
Per Week	259.99				 $45.95 	 16.36 		267.79
03-Jan-11	325.1	17.1	34	 $3.139 	 $64.00 	 20.389 	 15.945 	 102,324
07-Dec-11	218.4	16.6	24	 $3.219 	 $46.50 	 14.446 	 15.118 	 102,543
09-Jan-11	315.5	16.5	37	 $2.969 	 $120.50 	 40.586 	 7.774 	 102,858
12-Jan-11	341.5	18.2	35	 $3.239 	 $65.00 	 20.069 	 17.016 	 103,200
14-Jan-11	296.4	17.5	39	 $2.959 	 $53.30 	 18.014 	 16.454 	 103,496
19-Jan-11	324.7	17.9	36	 $3.259 	 $64.00 	 19.638 	 16.534 	 103,821 	104,103 cabin air filter
27-Jan-11	616.2	16.9	33	 $3.239 	 $68.20 	 21.055 	 29.266 	 104,437 	104,470 air filter
29-Jan-11	297.5	16.9	29	 $3.039 	 $100.00 	 32.906 	 9.041 	 104,735 	104,760 oil change filter rotate tires lube yoke
04-Feb-11	311.58	14.7		 $3.279 	 $69.50 	 21.196 	 14.700 	 105,047
05-Feb-11	217.25	14.7		 $3.079 	 $45.45 	 14.779 	 14.700 	 105,264
08-Feb-11	295.90	14.7		 $3.229 	 $65.00 	 20.129 	 14.700 	 105,560
18-Feb-11	283.25	14.7		 $3.339 	 $65.50 	 19.269 	 14.700 	 105,843
21-Feb-11	257.54	14.7		 $3.219 	 $56.40 	 17.520 	 14.700 	 106,101
24-Feb-11	246.12	14.7		 $3.479 	 $58.25 	 16.743 	 14.700 	 106,347
01-Mar-11	240.92	14.7		 $3.539 	 $58.00 	 16.389 	 14.700 	 106,588
04-Mar-11	296.09	14.7		 $3.659 	 $73.70 	 20.142 	 14.700 	 106,884
07-Mar-11	218.35	14.7		 $3.669 	 $54.50 	 14.854 	 14.700 	 107,102
12-Mar-11	264.23	14.7		 $63.649 	 $65.59 	 17.975 	 14.700 	 107,366
12-Mar-11	280.04	14.7		 $3.649 	 $69.51 	 19.050 	 14.700 	 107,646
15-Mar-11	123.80	14.7		 $3.799 	 $32.00 	 8.422 	 14.700 	 107,770
18-Mar-11	274.74	14.7		 $3.799 	 $71.00 	 18.690 	 14.700 	 108,045
19-Mar-11	567.3	17.9	40	$3.98 	$79.00 	 19.85 	 114,818 	114883
20-Mar-11	242.30	14.7		 $3.649 	 $60.15 	 16.483 	 14.700 	 108,287
22-Mar-11	248.24	14.7		 $3.849 	 $65.00 	 16.887 	 14.700 	 108,535
24-Mar-11	255.81	14.7		 $3.879 	 $67.50 	 17.402 	 14.700 	 108,791
27-Mar-11	402.85	14.7		 $3.649 	 $100.00 	 27.405 	 14.700 	 109,194
31-Mar-11	333.54	14.7		 $3.949 	 $89.60 	 22.690 	 14.700 	 109,528
05-Apr-11	304.80	14.7		 $3.979 	 $82.50 	 20.735 	 14.700 	 109,832
08-Apr-11	230.78	14.7		 $3.959 	 $62.15 	 15.699 	 14.700 	 110,063
10-Apr-11	69.60	14.7		 $3.769 	 $17.85 	 4.735 	 14.700 	 110,133
10-Apr-11	387.74	14.7		 $3.769 	 $99.41 	 26.377 	 14.700 	 110,520
14-Apr-11	277.48	14.7		 $4.079 	 $77.00 	 18.876 	 14.700 	 110,798
15-Apr-11	227.12	14.7		 $3.819 	 $59.00 	 15.450 	 14.700 	 111,025 	110424:  Oil, Filter Change, Tire Rotation
18-Apr-11	141.18	14.7		 $4.009 	 $38.50 	 9.604 	 14.700 	 111,166
21-Apr-11	1677.99	14.7		 $4.099 	 $58.00 	 114.149 	 14.700 	 112,844
25-Apr-11	111.84	14.7		 $4.009 	 $30.50 	 7.608 	 14.700 	 112,956
29-Apr-11	282.48	14.7		 $4.059 	 $78.00 	 19.216 	 14.700 	 113,239
30-Apr-11	143.63	14.7		 $3.889 	 $38.00 	 9.771 	 14.700 	 113,382
02-May-11	153.92	14.7		 $4.059 	 $42.50 	 10.471 	 14.700 	 113,536
05-May-11	147.00	14.7		 $4.059 	 $40.59 	 10.000 	 14.700 	 113,683
06-May-11	263.10	14.7		 $3.939 	 $70.50 	 17.898 	 14.700 	 113,946
11-May-11	283.39	14.7		 $4.059 	 $78.25 	 19.278 	 14.700 	 114,230 	110424
19-May-11	567.30	17.9	40	 $3.979 	 $79.00 	 19.853 	 28.575 	 114,818
22-May-11				 $3.939 	 $10.00 	 2.539
23-May-11				 $3.859 	 $78.50 	 20.343
26-May-11				 $3.959 	 $47.50 	 11.998
29-May-11				 $3.989 	 $230.70 	 59.772
03-Jun-11	397.3	17.9	32	$3.88 	 $82.75 	 21.33 	 18.624 	 116,176
05-Jun-11	361.5	16.6	32	$3.76 	 $104.89 	 27.90 	 12.955 	 116,538
10-Jun-11	365.9	17.8	36	$3.82 	$82.50 	 21.60 	 16.937 	 116,904
16-Jun-11	551.2	18.1	39	$3.78 	$70.40 	 18.63 	 29.587 	 117,455
18-Jun-11	291.9	17.3	41	$3.72 	 $112.30 	 31.03 	 9.407 	 117,747
20-Jun-11	341	18.1	39	$3.78 				 118,088
26-Jun-11	422.1	17.1	34	$3.57 	$100.00 	 28.02 	 15.064
29-Jun-11	381.6	18.6	41	$3.68 	$80.00 	 21.74 	 17.550 	 118,892
02-Jul-11	341.3	17.6	35					 119,233
03-Jul-11				$3.54 	$72.40 	 20.46
07-Jul-11	335.3	17.6	36	$3.66 	$73.00 	 19.95 	 16.806 	 119,568
10-Jul-11	293.1	16.4	38	$3.50 	$64.75 	 18.51 	 15.838 	 119,861
15-Jul-11	371.5	16.8	33	$3.68 	$69.55 	 18.91 	 19.651 	 120,233
17-Jul-11	249.5	17.8	38	$3.50 	$50.70 	 14.49 	 17.218 	 120,483 	121000 oil, filter, tires, lube yoke, diff
22-Jul-11	297.2	19.1	42	$3.66 	$60.10 	 16.43 	 18.094 	 120,780
24-Jul-11				$3.52 	$68.25 	 19.40
28-Jul-11	311.6	18.5	36	$3.69 	$67.00 	 18.16 	 17.156 	 121,354
30-Jul-11	285	18.9	38	$3.54 	$54.50 	 15.40 	 18.506 	 121,639 	 19,640
05-Aug-11	357.5	17.9	35	$3.70 	$78.50 	 21.22 	 16.847 	 121,996
06-Aug-11	276.4	17.3	38	$3.54 	$61.00 	 17.24 	 16.035 	 122,273
12-Aug-11	315.9	18.5	41	$3.64 	$64.00 	 17.59 	 17.961 	 122,589
13-Aug-11	245.3	18.2	40	$3.53 	$52.00 	 14.25 	 17.210 	 122,834
18-Aug-11	346.3	17.9	38	$3.56 	$72.20 	 20.29 	 17.070 	 123,181
21-Aug-11	329.1	17.8	38	$3.50 	$70.00 	 20.01 	 16.449 	 123,510
26-Aug-11	339.7	19	38	$3.60 	$67.00 	 18.62 	 18.249
27-Aug-11	249.6	18.5	45	$3.50 	$50.00 	 14.29 	 17.468 	 124,099
02-Sep-11	351.3	18.1	37	$3.74 	$77.00 	 20.60 	 17.058 	 124,450
09-Sep-11	560.9	17.7	41	$3.80 	$62.25 	 16.39 	 34.228 	 125,011
10-Sep-11	263.9	17.9	41	$3.60 	$113.20 	 31.45 	 8.390 	 125,275
16-Sep-11	346.1	17.6	40	$3.80 	$79.25 	 20.86 	 16.591 	 125,621
23-Sep-11	544.1	18.1	43	$3.80 	$70.45 	 18.54 	 29.341 	 126,166 	Partial AMPM
26-Sep-11	369.2	18.5	43	$3.72 	$30.00 	 8.07 	 45.761 	 126,537
29-Sep-11	530.6	18.1	42	$3.72 	$75.50 	 20.30 	 26.137 	 126,696
27-Nov-11	800.6	15.1	19	$3.55 	$75.00 	 21.07 	 37.994 	 127,497 	127885 oil, filter, air filter
02-Dec-11	164.2	17	26	$3.44 	$36.70 	 10.49 	 15.653 	 127,661
03-Dec-11	251.8	17	45	$3.34 	$94.85 	 28.41 	 8.864 	 127,913
10-Dec-11	268.1	17.8	44	$3.32 	$54.00 	 16.27 	 16.478 	 128,557
15-Dec-11	325.5	18.4	36	$3.42 	$64.40 	 18.84 	 17.280 	 128,557
17-Dec-11	259.8	17.6	46	$3.29 	$52.30 	 15.90 	 16.340 	 129,142
23-Dec-11	340.3	19	40	$3.38 	$64.75 	 19.16 	 17.758 	 129,483
24-Dec-11	247	17.4	48	$3.27 	$49.70 	 15.20 	 16.248 	 129,730
28-Dec-11	247.1	19.8	50	$3.40 	$45.40 	 13.36 	 18.501 	 129,971
30-Dec-12	268.9	18.5	41	$3.27 	$50.75 	 15.53 	 17.320 	 130,246 	 8,607
	27560.71	16.6	37.9	 $4.31 	5968.89	1753.2	15.7	 28,247
I took my biggest hits from tires as well. Nothing noticeable from lift alone, though I only ran a lift without bigger tires for like... a day :)
I know a lot of people say their MPG computer is WAY off... That's never been the case for me. Mine's always been accurate within, I'd say maybe 1/4 of a mile when compared to calculated values. Even after the mods once the correction factor is accounted for. Guess my baby is just good like that :)
Anyway, throughout her stock life time we got around 17.9 mixed driving average. now it's closer to meh... ~14 or so. Oh well, at least is 14 AWESOME miles!!!
I have gotten up to 22-22.5 on long highway trips to the coast using hand calculations. The dash meter would read 24-25mpg.
