Gas tank and mileage indicator issues...
Where exactly-specifically is the "fuse for the dash gauges" located at?
Is it under the dash, engine compartment or ?
Thanks for the tip! I'll first give this a try and see what happens. Hopefully it'll correct the problem, if not then I'm still going to have to order the part and drop the tank.
It's a fuse under the dash. The access to it is above your left knee covered by a pop off plastic cover. (About a 4"x4" piece of plastic) I don't remember exactly , what fuse it is. Should be able to look on said plastic cover and figure out which fuse it is from the diagram. I'll check when I get in my truck in a bit.
Sorry about the delay. The fuse is under the dash. It's a 7.5 amp fuse in the spot for "gauge" per the diagram on the fuse box cover.
Philthyphilthy
