gauge cluster bulb
4runnerfevr
Trying to locate the ECT bulb in a 2001 Toyota 4Runner SR5 gauge cluster. does anyone have a diagram or know of the location of this bulb? I know it's the bulb because the switch works. I have been to the dealer and Auto parts store and no one has a diagram for a 2001 SR5 4Runner. I found diagram for a 2000 4Runner, but not the same.
Thanks for your help
in my '01 the "ECT PWR" light is right below the tachometer near the 7000 RPM range. I believe the bulb is a #74 (green).
http://www.toyota-4runner.org/3rd-g...-climate-control-dash-bulbs-2000-limited.html
Similar procedure to the link above but as I mentioned the location is a bit different. It's more towards the center, bottom cluster in the 01-02. If you're not sure, when you have the cluster out, you can tilt it around until you get the right lighting and you should be able to see the text.
seltzernator
