airdreams1
Okay let me first start off by saying "yes I have read and researched a bunch."
I am going to be running 33 inch tires (not any larger) and I know that the recommended ring and pinion is 4:56 with manual trans............ keep in mind that I already have a good condition V6 third member with 4.56 gears....... But a little bit more research I found that it will cost me nearly double for the front reverse cut 4:56 gears for my High pinion diff.....
This brings of a dilemma, I'm wondering what would it do if I ran 4:88 front and rear? I could literally by both the front and the rear for just a few dollars more then the cost of the single 456 front set.
So, If I'm understanding correctly it should make my speedometer read a little bit off. But my real question is how does it affect my power and torque / crawl, take off, towing, top end?[
