Gen 5 4WD Connector part numbers needed
Hi all 4Runnerers!
I am installing a 4WD transfer case (VF4BM) from a Gen 5 in a portaled Gen 4 behind a 2UZ engine, and am in need of both connectors that are connecting to the 4WD ECU that controls the case.
Here are pics of the ECU and the connectors. The part numbers are located on the side of the wires but that's the only pic I have of the connectors and they aren't visible.
It should be a 5 digit number. Here is also a pic of the connectors' diagrams if you have a list with the connectors' parts numbers at hand (all connector part numbers start with 90980-XXXXX where X is the part that is on the connectors themselves):
406797d1694681708-gen-5-connector-list-part-numbers-4wd-transfer-case-5th-gen-89533-jpg
406798d1694682073-gen-5-connector-list-part-numbers-4wd-transfer-case-5th-gen-89533-png
The ECU I believe is located on the passenger's side somewhere near the right foot, or more likely behind and slightly above the dash...not quite sure, as there arent that many 4Runners here in Bulgaria and hardly any Prado 150s to check or part out.
You should be able to find them either on the car, or if you have the connectors list (the connectors are identified by the codes F46 and F47 on the list and both should start with 90980-). They will help me order them new. Sadly Toyota here aren't able to find them for me, as it is not a part that they can look for in the DBs.
Several of us have swapped the AWD electronic TC to the manual, but not the reverse that I know of. Maybe check out the GX or IH8MUD forums.
delislerebecca
