TeryT
My 2003 V8 4Runner just turned 89,000 miles, so I'm starting to think of the timing belt replacement. A couple questions:
1. Is there any sort of grace period that Toyota allows for a timing belt replacement, or they firm about 90k? In other words, if the thing had 91,000 on it and the old belt broke, would they disallow a warranty claim (under a Toyota Platinum Warranty)? I've heard people on here talk about changing the belt at 96k, but how much of a risk is that?
2. Is there any reason to not have a cheaper non-dealer do the work? I still have until 100k miles before the extended Toyota warranty is up, and wonder if I should just have it worked on by only the dealer until then.
3. The Toyota dealer said it is not always necessary to replace the water pump with the belt. I had always heard they should both be done together, as it's just good preventive maintenance, since the pump will likely fail before the timing belt is replaced again. Is the dealer just trying to get me back in for an expensive repair "down the road" so to speak?
Thanks!
Thanks!
